Tamiya TRF415
Hey guys I've just got my hands on a TRX 415 MXS. Now I've raced with a TA04S tub chassis...and a XXX-S G+. Now I have the XXX main Chassis set-up book. I'm trying to get a good place to go to get info on how I need to set this car up for carpet rubber. Also, I'm looking for insite for how good this car is on asphalt?
Thanks again for all the help.
The 415 is very smooth and awesome on asphalt. As for rubber tire carpet setups, just do a search in this thread (upper right corner) for "vegas" and or Martin. He has his setup from Vegas posted up for 19t and Mod.
Martin Crisp, the author of the XXX-Main Chassis Setup book also run the TRF415MSX. Sometimes he comes onto this forum and post some setups.
Thanks all I'll try that.
Originally Posted by TRF415boy
Y parts are the blades, which includes the new diff nut retainer for the alloy outdrives.
Most likely when my re-building is complete, will have to figure out what to do w/ my fully hopped up TRF414M.
any idea where am i able to get marc's setup for msx?
Which one? One is posted in the thread and on RCZone for rubber tire carpet and another is posted on Tamiya Japan site.... I also have Satoshi's Reedy Race setup in one of my Japanese Mags...
some setups for the asphalt..thanks!!
A few pages back there was a link to his setup that he used in Japan. Rubbers/asphalt/Cold conditions.
http://tamiya.com/japan/products/493...xmarcc_int.pdf
This is the only Rheinard setup for asphalt that I have seen. I haven't tried it, I like my setups to much.... Ha..... I will try it sooner or later tho.
thanks mate any idea what are the springs he used? cant read japanese..
arrhhh...
Up front he used Tamiya blue's, on the rear he used Tamiya Yellow's
thanks!!
Hi Guys,
I've just bought the LE white colour spring set.Was condering do they have a slight difference in sping tension due to extra powder coating??
If they have extra powder coating, then Yes, the tension will be different. I removed the power coating from some Tamiya yellow springs a few months back, then I ran them back to back with new Tamiya yellow springs (with coating) and there was a slight difference. It does soften them up a fraction.
