Tamiya TRF415
hey guys, i have a general question. what is the difference between the ms and non-ms??? are there any other versions?
thanks
marshal v.
thanks
marshal v.
thanks
marshal v.
thanks
marshal v.
To view the difference of the two kits, click on the ff links :
TRF415
TRF415MS
Hope this helps.
Originally Posted by JRRobiso
The std kit (non-ms) has the stardard arms & 3.0mm bottom plate. The ms version has the light weight rev arms (EVO4), 2.5mm bottom plate, re-designed f/r shock towers, re-designed motor heatsink & spur gear backing plate.
TRF415
TRF415MS
Hope this helps.
TRF415
TRF415MS
Hope this helps.
thanks alot, im asking this for a friend. what car is better on carpet with foam tires?
how is the durability of the std? he does hit some stuff.
right it is extremely hard to break.have driven for almost a year w/ it, have only broke 1 lw arm, and 1 c-hub. i also have a question. i have a regular 415 with the reversible arms and ms shock towers. will it be any good on carpet with a spool?
msx
Tamiya wins!!!!!!! msx all the way
TryHard's TRF415 Set-ups
And also TAMIYA TRF415MSX - Mark Reinhard wins Foam Mod Class!!!!!!
Tamiya TRF Rules - TRF415MSX see you in December!!!!!!!
Hey I'm thinking of buying a new carpet sedan. so I need help on this question.Is this the order of the cars for the 415.
415
trf 415
trf415ms
trf415msx and the final question is can you buy the stock 415 and buy a msx conversion and would it truly be upgraded all the way . thanks. or is the new car as mentioned at the tokyo show even newer than the trf415 msx. am I confused I think so.
415
trf 415
trf415ms
the 415 is the trf415, then the ms, now the msx conversion, will be for the ms kit, unless you have a trf415 with lwt suspension. there will be a new kit, the trf415 refine 2 which is the msx kit, it will have one or two upgrades the conversion wont have. if your waiting to get something id wait for the full kit, if you have an ms car then just get the conversion.
I greatly appreciate the reply and how you made it clear. thanks
How did Mark R get 28mm foams to fit on his 415 msx?
thanks
thanks
thanks
thanks
