Tamiya TRF415
#8746
Now that it's official...If you guys think the lightweight spools out there are light, boy are you in for a treat with the new 415 spool. Weighs almost like nothing. It's an aluminum center shaft (looks like one of those chassis posts) with delrin outdrives that are capped off with the blue outdrive rings. The outrives are keyed with a pin that goes through the aluminum shaft, with the bearing going over the shaft to keep it in place. I don't have pictures but DJ's got them on his car...Tiiiiyt!
#8747
Tech Legend
Trader Rating: 51 (100%+)
#8749
But think about it, Tamiya is making this with delrin outdrives, so it soundslike they will be replaceable, and with that said at least you should be able to get the outdrives Separately.
#8750
just a quickie, for those who have ordered the new dj pro module suspension, how are you going to get more than 1.5 degrees rear toe on the car when it comes with zero on the hub?
#8752
anyone know when the tamiya spool will be available, if it is already where can i order it.
#8753
#8754
LW suspension arms and stock arm
Since I've been rained in for the past three weeks. I have just too much time on my hands..Since we can mix up the DJ rear arms with the LW arms, can we use the front stock arms with the rear LW arms. I ask this because the stock has less slop and is stronger then the LW front arms.
#8756
#8757
sorry, double post
#8758
Steve Wang
#8759
Re: LW suspension arms and stock arm
#8760
Order for the DJ Suspension
Originally posted by SpeedTech
Delrin outdrives will not last, which is why Ti Racing don't even make the Delrin outdrive version of their spool any more (they are all now aluminum outdrives).
Steve Wang
Steve Wang
Can you help to check on my order? I have not had a reply on the order since i confirmed it for delivery via intl shipment.
The order number is 12934.
Thanks and Regards
