Tamiya TRF415
#7921
Re: Re: Re: Regarding pic dsc00707.jpg
Originally posted by Arun
Just the Pro4 steering knuckle...the c-hub is LW tamiya. You must put a thin shim on the top and bottom of the knuckle. This is how we ran them at the Snowbirds.
#7923
#7925
Originally posted by Nexus
kumpol, arun, dawg, or other guys running foams.
which foams are you finding fit best on the 415 wheel hexes?
i generally run parmas but the seem like are not that snug (kind of wobbly) until you tighten them down.
I haven't heard about any wobbling issues.
#7926
I run the Jaco's on my 415. I have never had a problem with them and the last time I checked they had the largest rim diameter of any foam tire out there so they fit better on the front of the 415.
#7927
I used Parma all this winter carpet season, with 0 rim issues. No cracks, bent or broken rims.
#7928
thanks for the foam input.
pics of the 415 i'll be running:
http://home.comcast.net/~anthony.isl.../nexusTRF1.jpg
http://home.comcast.net/~anthony.isl.../nexusTRF2.jpg
http://home.comcast.net/~anthony.isl.../nexusTRF3.jpg
#7929
#7930
ko.
yea...i'm going to run the car on rubber tires first just make sure the car is working right.
once i recieve the yokomo/tamiya parts to build a front diff i'll be set to run foams....anyone have one for sale??
what is the part number for the center one-way thing i need to replace?
#7931
Hey Anthony,
Your 415 looks great. What ESC is that? Are you running a 4 wire set-up? Have you considered moving to a 3 wire set-up? Where are you running at this weekend?
Khal
Khal
#7932
Regional Moderator
Do you have any shims on the wheel hex?
I have no shims in the front.....I don't notice any problem.
oh, I also use "TB-Evo IV Ball-Head King Pin" part# 51101 so the wheel won't rub any ball cup.
Don't screw in the king pin too deep - it will bind the c-hub.
#7933
Originally posted by kumpol
I love Parma tires and Alfa body for carpet racing.
I`m still thinking what to buy to next body.
Do you think at that Parma Alfa is best body for carpet racing? Anyone agree that...
What about asphalt racing, which is the best for that?
#7934
I have done both the 3 and 4 wire setup off the GT7...just wanted to try running the motor and battery wire on their own instead of splicing in with a 3 wire setup.
foams - parma's are awesome and cheap. another tire people might want to try are T M Racing foams....they are high quality and the wheels are a little bigger then other brands.
#7935
my car tech415
