Like Tree3Likes
Tamiya TRF415
Old 03-07-2005, 04:43 AM
  #7696
dawgmeat's Avatar
Default Re: .
Originally posted by Raul Garcia
Hey guys check my for sale post.
MI2/415/???????
dawgmeat is offline
Old 03-07-2005, 04:50 AM
  #7697
rraden's Avatar
Trader Rating: 259 (100%+)
Default Hey guys check my for sale post.
Question on your sale post. You mention using EVO IV upper king pin cut down 2mm. Is this to fit foam tires on the car? If so, can you share exactly what you did. I've modified my front C-hub set up several different ways and was unhappy with all of them. Maybe your method is the ticket.
Thanks!
rraden is offline
Old 03-07-2005, 05:39 AM
  #7698
Hi all
I'm going to be getting a new car soon, and have narrowed it down to the 415MS or the new Losi (I don't want opinions on which to get!)
I mainly race on carpet with foams and outdoor ashphalt here in the UK. I know the car is very well spec'd as std but what additional parts would you reccommend I got? Also, do the current Losi springs fit the 415 shocks? I know lots of people are using the AE springs, i just have lots of Losi springs from the xxxs i run at the moment.
What breaks most often - here in the UK it seems its quite difficult to get hold of tamiya parts, so I want to get some spares before I break them (hopefully this will change now Spash is racing Tamiya)
Also, could someone please post the list of parts required to make up the front diff - and also to make up a spool (sorry I looked back through the other pages but couldnt find it, just tell me what page its on will be great)
Thanks for any help
OLI
UK
Bigger Brother is offline
Old 03-07-2005, 06:18 AM
  #7699
Turbonium's Avatar
Trader Rating: 27 (100%+)
for the diff parts, see the username forty6.... he has all the parts listed in his signature. mostly frequently asked questions!!!
Turbonium is offline
Old 03-07-2005, 06:33 AM
  #7700
V12
V12's Avatar
I think the MS is not the perfect car for carpet. The stock 415 is much better there. On asphalt it seems the other way.
From what I know the XXXS springs wonīt fit on any other car. They are just too big in diameter. You canīt use them with the Tamiya but from what I have heard here even the new Losi needs completely different springs.
AE and Xray springs are working with the 415.
Regarding spare parts the stock 415 usually needs no spares. The MS tend to break suspension plastic parts and the small 580 wheel bearings.
V12 is offline
Old 03-07-2005, 07:27 AM
  #7701
Tommy Bergfeldt's Avatar
Wellwell, my setup from the race
link to JPG
Tommy Bergfeldt is offline
Old 03-07-2005, 08:06 AM
  #7702
V12
V12's Avatar
link to JPG
regarding castor from your setup this is 4° with the old suspension
V12 is offline
Old 03-07-2005, 08:41 AM
  #7703
Exactly what i thought, thanks!
Quite many things you have to learn with a new car
Old 03-07-2005, 02:09 PM
  #7704
The Evicerator
Default World's Setup
So did Tamiya ever make Rheinard's setup from the Worlds Available? Or did anyone ever peice together a setup sheet from information gathered?
Steve Weiss is offline
Old 03-07-2005, 02:17 PM
  #7705
V12
V12's Avatar
I think a lot of people want this setup but maybe nobody has it. Even if you look at the pictures there are so much details left which you canīt see there. But these will effect handling as well.
V12 is offline
Old 03-07-2005, 02:42 PM
  #7706
rtypec's Avatar
Wasabi Steve! I don't have it. I believe that Marc had a pit benifactor from Japan who did all the setup work.
rtypec is offline
Old 03-07-2005, 02:44 PM
  #7707
The Evicerator
Yeah, I know he didn't really work on his car there
I just figured by now some information might have trickled down...
I need to start my reedy race testing and figured I might as well have a decent starting setup
Old 03-07-2005, 02:58 PM
  #7708
rtypec's Avatar
I hear ya. You probably don't want mine because the best I could do last Saturday was a 13.89
*edit* seriously...because I don't have the LW suspension on the car.
rtypec is offline
Old 03-07-2005, 05:01 PM
  #7709
Burlap's Avatar
I'll be getting a standard 415 second hand this week. What are the main differences between the two cars (I race ashphalt) and can I hop the standard 415 up to MS spec?
Burlap is offline
Old 03-07-2005, 06:35 PM
  #7710
TryHard's Avatar
Well from the pictures of marcs car it's possible to pick up some information, however setup stuff like camber, droop, toe (even on the suspension blocks, only the R/R block is visible, although you can tell he ran a flipped block on the F/R) you just can't tell
TBH though, the stock setup is pretty awsome, there are some setup sheets around, including on my site.
HiH
Ed
TryHard is offline
