Tamiya TRF415
#7501
I take it that means the setups you've tried are working then custom
And boy i'm feeling old today, hit the rip age of 23..... considering most other people around me here at uni are in their late teens, it makes you feel well old...
Later
Ed
Later
Ed
#7503
hey guys, need some help with my 415 on carpet. It seems to have an overall lack of grip, on power push and off power loose. I'm running white front/yellow rear springs, yellow front bar, no rear bar, 1.5 degree rear toe, old a-arms, aluminum rear hub carriers with the camber link mounted furthest out on the hubs themselves. Thanks in advance.
#7504
#7505
oneway i assume? at the Novak race, i ran with yellow/yellow spring combo, on the advice from Chris T.... red bars all the way around, 2-degree rear toe...
from what i have experienced, this car likes a little softer spring than most.
just remember..... oooooooooooooooooooooooooooo those are cheerios, dumbass....lol! remember that one, Gary?
good luck at the TCS, and tell Scotty and the gang that the OK boys said hi!!!! and we will see him in Vegas!!!
#7506
Jimmy
#7507
#7508
Better than EVO III
Hi All,
I have a Surikarn EVO III now and am considering the 415, but am not sure if it is worth the extra money over an EVO III. Anybody who has driven both care to offer up opinions here? It is a pretty expensive kit and I am not sure how easy it will be to sell my EVO III.
Bottom line question: how awesome is this car?
Khal
Khal
#7509
Re: Better than EVO III
Originally posted by KDagh1
Hi All,
Khal
Hi All,
Khal
#7510
I've never been to trackside nor do I have much experience on carpet so this may be completely wrong Try any or all of the following (I'm certain practice time is going to be limited ):
-softer front spring and red sway bars like others have said.
-reduce rear downtravel (less weight transfer to the front off power during initial turning)
-reduce front downtravel (less weight transfer to rear on power for a little more steering)
-move rear camber link inward. If I remember correctly, it allows the rear to roll more while cornering and gives you a better feeling on when the rear will "wash" out on you. Outer most hole let the rear corner flatter and could cause a very quick "washing out" oversteer feel. Atleast this is what I've experienced when I played with those camber link positions.
-hmm there's a whole slew of other things you can try, such as shock positions, camber link spacing, etc, etc. BUT since you didn't post any other info about your setup you're up poo creek ya knob! hehe j/k We still buds, right?
I hope this helps but I don't know how well it will work in your situation. Have fun.
#7512
Hi All,
Khal
Hi All,
Khal
I do like the 415 better than the EVO III even better than the SE version. I am faster and more consistant wit this car. More realiable car IMO as well.
For carpet racing, stick with the stock 415...the MS is not the right car for tight, carpet tracks. If you run on ashpalt, get the 415 MS.
#7513
415
We have a tight high grip asphalt track. Do you think this car is the right choice for me? I'm so confused.
Please give all pros and cons you can think of on this kit. I will more then like only run on asphalt.
Is chassis tweak a major issue as I have seen posted?
#7514
I may be in contradiction with everyone else here (going harder on springs instead of softer), but I suggest you try Marc's LRP TCM winning setup. You can find it on RC Zone or RC World.ch, but it's close enough to the stock setup that I can tell you what it is.
Basically, it's the stock setup, with white springs on front and blue on rear, no ARB's, no shims under the suspension blocks, 2° of toe (B-D blocks, and alloy rear hubs, with the upper link located in the outside hole and 1mm shim under the ball), 2° or camber all round, 1° toe out on front. He was using no additive on the front and full on the rear, and his car was awesome like that (i was there ) . I tried it myself on high grip carpet with CS22's (controlled tyres/inserts/rims) and the car worked very well indeed.
#7515
kdagh1.
what's up man...i'd grab the 415!
i'll most likely be running that soon over my Pro 4. from asking i believe the stock 415 will be best on the indoor carpet tracks we race at. then come summer if you run it outdoors just add the LW suspension.
there are atleast 4 415 drivers at RSJ and a few at trackside and/or AJs.
good luck at TCS
g12314.
throw it down at the TCS and win one of those Evo 4s!! call me up if you need anything or if there are cheap tamiya things for sale!!
good luck at TCS
g12314.
