Tamiya TRF415
RC Pro-Module Rr Susp Set - Fits 415-Evo IV
Item #1004
MSRP: $119.00
http://www.tamiyausa.com/product/ite...roduct-id=1004
i got bad experience with alumn. I bend alot of my alumn parts lately.
. Now my rear Bulk head? oh no..
Trader Rating: 23 (96%+)
Ultimate Solution for LIPO.
Fresh From TRF416 thread.
http://www.rctech.net/forum/4952879-post3022.html
Im ordering it now.
Im ordering it now.
Can anybody recommend a good ride height for a MSX-MRE on rubber-tire/asphalt? It's a tight technical parking-lot track with relatively short straights...
Thanks: -Sean
Thanks: -Sean
If you want to have the measurement it will take sometimes before I go measure it. Kinda busy lately. What I did was grind and measure. Do it few times and you are done. It only takes 20mins.
I don't know which shop will do for you but I grind myself using 6" Mill Bastard by Nicholson. You can get it from ACE Hardware. Check it out here
You use only that? (6" Mill Bastard) i got few sticks of that bastard
I'll give it a try, and hope i dont bend my bulkhead
thanks Killer
thanks Killer
Kilokhan where can I purchase that lipo tray? I love the design and it would work with my big lipos!
http://www.feralbatteries.com.au
But is currently sold out. Im waiting for the new shipment.
Here you go.
I run a 415msx with 4 mm chassis for local carpet racing . Lately I have been having major problems with my ball cups popping off when I just brush a corner . I have never in 4 seasons of racing this chassis had this problem before. I tried installing New Tamiya steel ball and New Tamiya ball cups , but it actually got worse. Anyone have any suggestions ?
Mike
Mike
If its a fairly smooth parking lot you could try 5mm front, 5.5mm rear. if its a bit bumpy try 6mm front and 6.5mm rear.
