Like Tree3Likes
Tamiya TRF415
Old 01-02-2008, 03:43 AM
  #19516
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Very helpful Nick....loser!
Jamie
J.Gonzalez is offline
Old 01-02-2008, 04:09 AM
  #19517
TryHard's Avatar
Originally Posted by xtrememadness
i currently run corey lewis reedy setup outdoors and the car handles beautifully. consistently up there with the fast guys. im gonna run this setup on carpet with rubbers. any suggestions? thanx. oh i run an msx mre.
You could also try this setup Carpet Wars Rd6 2006 setup.
It's one I've used to pretty good effect indoors, managed a few A finals at the carpet wars with it now, and most people whoever tried it have good things to say about it I have dropped back to only 0.5mm under the suspension blocks, rather than 1mm, and a couple of other changes (A/E rear blocks, and 45/40wt oil in the shocks), but thats a fairly good base to start with.
I'm going to be running my 416 for the first time this weekend, and lending the 415 to another racer.... I'll get his feedback on it as well
After this weekend though, looks like the MRE will be dropping back to backup/wet car, it's served me well over the last year and a bit, as did the previous cars too...
Ed
TryHard is offline
Old 01-02-2008, 08:32 AM
  #19518
J.Gonzalez's Avatar
Thanks Ed,,,however what exactly is an ho rear hub carrier?
Old 01-02-2008, 08:48 AM
  #19519
TryHard's Avatar
It's the hub that comes standard with the MRE. If you look on the rear hubs, you should see it's marked H0. There are other hubs avaliable marked as 0°.
They provide the same level of toe-in, but the H0 hubs are 0.5mm lower.
This aids rear traction, and also changes the droop and rear roll centre slightly.
HiH
Ed
TryHard is offline
Old 01-02-2008, 11:39 AM
  #19520
habis's Avatar
Originally Posted by DRAG_ON
Has anyone try to fit 416 pulley on 415? will they fit without any modification? and how bout the belts, will the 416 belts can be used for 415 MSX using 36 front pulley and 18 middle pulley?
you can only fit the 18 teeth pully to the MRE centershaft http://shopping.rcmodel.hk/popup_ima...D=8999&image=0
, but you wont find a belt that fits 100%
the closest is the x-Ray T2 rear belt and HB Cyclon front belt. but the rear belt is very loose.
I havent tried the 416 belt, but they are totally different lenght, bulk heads are farther on front and closer on rear.
the smoothest solution - to my humble opinion - is the 35T pully fittet with 12x 3mm balls, using the 416/501x Diff plates, and with 17T pully(3 racing) on MRE belt. This gives a smooth diff with a IR of 2.055 - the same as the 416
habis is offline
Old 01-02-2008, 11:46 AM
  #19521
The new rear belt for the xray t008 is 183mm and a perfect fit for the 18/37 pullies.
Mr_Orange is offline
Old 01-02-2008, 11:49 AM
  #19522
habis's Avatar
Talking
so to run the 18/37 the combo would be:
T2 ´008 rear
HB cyclone front
habis is offline
Old 01-02-2008, 11:56 AM
  #19523
That would be correct, just make sure you get the right xray belt (183mm) as they also have a 186mm one for the t08.
Old 01-02-2008, 05:15 PM
  #19524
xtrememadness's Avatar
thanx ed. that setup looks good. i will try it. i appreciate the help what do you think about running a spool. i cant drive with a one-way to save my life:
xtrememadness is offline
Old 01-03-2008, 01:19 AM
  #19525
TryHard's Avatar
If your running a spool, maybe try B/A up front if you want some more front end. Otherwise, should be fine.
If your running stock, certainly try the one-way, you'll be faster for sure. For 19t, thats kind of the cross over point from one-way to spool IMO, whereas as mod, most top guys seem to be running spools indoors.
HiH
Ed
TryHard is offline
Old 01-03-2008, 05:43 PM
  #19526
cool thanx ed. im gonna try it out on sunday. i will let you know how it works out. thanx again for the help bro
Old 01-05-2008, 07:24 AM
  #19527
mitsubishi's Avatar
Has anyone tried using a futaba brushless motor bls 251 in their 415msx using 6 cells? mine doesn't seem to work? I know that this is for gyro but just want to find out if somebody has tried it? thanks a lot...
mitsubishi is offline
Old 01-05-2008, 04:06 PM
  #19528
TryHard's Avatar
Well, I guess the setup is half decent, as the guys who tried my 415 this evening seems very eager to make the car his own!
TryHard is offline
Old 01-07-2008, 12:04 PM
  #19529
Trader Rating: 42 (100%+)
Where can I find setups for the original 415 w/ standard suspension....no msx, msxxrreeesurikarnadachimmxx.
415 on carpet...19T or Modified.
Nexus is offline
Old 01-07-2008, 02:37 PM
  #19530
TryHard's Avatar
http://www.thard.co.uk/setups/pages/STD.html
And theres this one too...Marc R - LRP '04
TryHard is offline
