Like Tree3Likes
Tamiya TRF415
Old 08-15-2007, 08:13 AM
  #19081
Originally Posted by Toughbeard
but with 1.75 IR that car just flies. I used to run 23T in mod class with it. massive 24 center pulley
I may end up building a 20T center pulley for kicks and try it out... but mostly I would want it for stock racing.
Now why would you want to do that? According to you it's just going to add more friction.
jinsc is offline
Old 08-15-2007, 09:56 AM
  #19082
TryHard's Avatar
Originally Posted by TryHard
Well, I've got the parts on order to do this now too.
And also the 501x 18t centre pulleys... I'll try this all out at the forthcoming KO GP over here in the UK, be intrigued to see if I can notice a difference.
BTW, I'll have an updated version of the gear chart on my site soon, will have charts for the many different pulley combinations (35/16, 36/16, 35/18, 36/18 etc)
Ed
it's up
http://www.thard.co.uk/excel/415GearingChart.xls
regards
Ed
TryHard is offline
Old 08-15-2007, 10:07 AM
  #19083
Chris V
We were up in Whistler BC last weekend and I had to tell the Fokker story of our border crossing. I had everyone in tears.
For the rest of you imagine a border crossing agent, Fokker (said with slight accent) and a Ford Expedition full of RC Geeks.
Hope all is well.
Dan
Difuser is offline
Old 08-15-2007, 10:44 AM
  #19084
Hey all
I managed to made that new diff and i have to say, it`s smooth like butter
Took couple pics also
http://i205.photobucket.com/albums/b...PICT0003-1.jpg
http://i205.photobucket.com/albums/b...PICT0005-1.jpg
Cruisaaja is offline
Old 08-15-2007, 02:35 PM
  #19085
C van der Hagen's Avatar
Originally Posted by peejay
I assume that you are suggesting that there should be 2 rings of 8 balls, rather than drilling 8 extra holes in the outer ring? Have you done this?
yes
C van der Hagen is offline
Old 08-15-2007, 02:41 PM
  #19086
Originally Posted by Difuser
Chris V
Hope all is well.
Dan
Hi Dan!
I'm fine! thanks.
How are you?
Maybe I will be visit Seattle next year. We can try to cross that border again
Old 08-15-2007, 03:40 PM
  #19087
If you come over let me know I have not been racing as much as I had been in the past. Business is going to good to have time to race.
Difuser is offline
Old 08-15-2007, 07:19 PM
  #19088
Tek Nickal's Avatar
Originally Posted by Cruisaaja
Hey all
Does anyone have any instruction on how to make that diff?
Tek Nickal is offline
Old 08-15-2007, 08:29 PM
  #19089
Trader Rating: 72 (100%+)
Post # 19055
patrick is offline
Old 08-15-2007, 08:49 PM
  #19090
Xanavi_R34's Avatar
Hey all
How did you do it bro??? Mine seems to be not smooth like a butter... How did you smoothened out the diff pulley??? What tools did you use???
Xanavi_R34 is offline
Old 08-15-2007, 08:50 PM
  #19091
Xanavi_R34's Avatar
Here you go sir...
http://racingfactory.wordpress.com/
Old 08-15-2007, 10:31 PM
  #19092
Like Kentech`s instruction told:
"The next step is to remove some material from the diff pulley. You need to remove the raised plastic rings around where the diff balls normally go. You should remove this on all holes, both inner and outer ring and both sides"
I used dremel on that phase and take your time when you do that, don`t hurry..
Old 08-15-2007, 10:35 PM
  #19093
Xanavi_R34's Avatar
I did sir... All of it... What do you mean by inner and outer ring???
Old 08-15-2007, 10:45 PM
  #19094
That mean, at you need to shave off inner and outer cirle`s raised plastic rings both sides, you know?
That mean at area is flat after that when you can put balls on the holes, wright?
Old 08-15-2007, 11:00 PM
  #19095
Default CARPET RACING WITH A 415MS
We are about to get our first carpet racing track here in Sydney Australia.
Do you guys have any tips or setups for a standard 415MS for racing on carpet, as most, if not all of us in Sydney, have never raced on carpet.
Cheers
PRO 2 RACER is offline
