Like Tree3Likes
Tamiya TRF415
Old 08-13-2007, 12:43 AM
  #19051
miccal's Avatar
Trader Rating: 23 (100%+)
Originally Posted by razzor
I have a TRF 415MS LE chassis that i ran a max of 3 times before i broke the lower chassis plate at our local club. Been waiting for a chassis plate for over 8 months and finally got it.
Why did it take so long?
miccal is offline
Old 08-13-2007, 12:32 PM
  #19052
RC MARKET's Avatar
http://www.rczone.net/
RC MARKET is offline
Old 08-13-2007, 02:09 PM
  #19053
Toughbeard's Avatar
Originally Posted by Tek Nickal
It says the TRF shocks are a new design. What else could they do to a perfect shock?
they may have done what Team Magic did with their shocks on the G4+ We built those shocks today on my car and all I can say is wow...
very similar to TRF shocks but the plastic parts on the TM are much higher qualit, no slop and the top part is one piece aluminium. Once this season is over I ll sell teh 2 sets of TRF shocks I have and buy one set of these babies....
except that like I said the 2mil chassis might be good to get to test, but untill the 416 comes out and gets to the MSX MRE level I ll be sticking with the 415.
the 415 needs a center mounted steering with the servo rotated 90 degrees... I hate cutting my servo ears just because someone messed up at the design phase
Toughbeard is offline
Old 08-13-2007, 04:04 PM
  #19054
Trader Rating: 32 (100%+)
guys, would the trf415 msxx lower deck set for stick type battery in the attached picture fit the mre? will this chassis be able to accept side-by-side packs, stick type battery, lipo 3200's and lipo 4800's?
Attached Thumbnails Tamiya TRF415-1000408108.jpg   Tamiya TRF415-1283696541.jpg
Rnold is offline
Old 08-13-2007, 11:29 PM
  #19055
Hey all
Take a look at kentech`s new diff building:
http://racingfactory.wordpress.com/
Cruisaaja is offline
Old 08-14-2007, 07:28 AM
  #19056
Guo Chean's Avatar
Originally Posted by Cruisaaja
Hey all
i thought he was runing 501X diff pulley instead of 36t pulley.
Guo Chean is offline
Old 08-14-2007, 08:42 AM
  #19057
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Guo are you running at 301 this Sunday for the warm up race/practice?
wyd is offline
Old 08-14-2007, 09:35 AM
  #19058
Guo Chean's Avatar
most likely will be at the track this sunday.
Old 08-14-2007, 12:00 PM
  #19059
I thought that too, but it`s TA05 36th pulley with 18 diff balls like you saw my earlier post
Old 08-14-2007, 01:54 PM
  #19060
Guo Chean's Avatar
i dunno whether we can used 501X pulley on 415 or not since i look over the pic the diff already have 12 diff ball hole but i think 18 diff ball will even last longer.
Old 08-14-2007, 10:56 PM
  #19061
Last night i chance that 18t middle pulley to my MRE. And HB Cyclone belt up front and xray 007`rear belt and they fit perfectly. Now IR chance 2.0 after that, so i must chance my gear ratio sheet. I may try that next weekend if not rain
Old 08-14-2007, 10:58 PM
  #19062
And after workday i`ll make that new 16 ball diff
Old 08-14-2007, 11:32 PM
  #19063
maxepower's Avatar
Exclamation Modified Tamiya diff!
I believe the website said to use the TA05 pulley and drill extra holes,but use the 501X diff plates. The diff plates are wider to compensate for the extra diff balls. Then use aftermarket Thrust bearings 2x6mm Squat S192. This makes sense!
This should be great for running brushless motors, they have so much torque it it wiped out my used ball diff after a couple of runs.
maxepower is offline
Old 08-14-2007, 11:35 PM
  #19064
Xanavi_R34's Avatar
Hey guys, what is the difference between the ball diffs "ball" that came with the kit (standard) compare to the tungsten ball ???
Xanavi_R34 is offline
Old 08-14-2007, 11:56 PM
  #19065
maxepower's Avatar
Tungsten Carbide is a harder material than the standard diff balls.
Ceramic is suppose to be stonger and more heat resistant than carbide!
Theoretically speaking of coarse!
