Tamiya TRF415
Originally Posted by Toughbeard
You are right about the current toe blocks being easy and I forgot to say that my bad and especially if you are changing width that is the only way. I just feel having the front fixed and changing the rear woudl be simpler albeit not as efficient...
on a second note I probably wouldnt said that if I had the blocks I have now all arrived yesterday. I am confused, yes, but I ll Live....
one question though. I have checked your web site and you have the blocks listed. you have the widths of the blocks do you have the total width of the car with certain blocks... (For ex. say if you put 1D on the back you are at 189mm and so on... etc..)
By the way any news on the 416 yet...
Regarding the track widths, it's something I haven't done. I have previosly measured the width of the blocks, and have the figures somewhere, so should be able to figure that out... will take me a while though, have a lot on over the next few weeks.
Regards
Ed
Originally Posted by TryHard
No 416 stuff yet, that I've heard of, bar there is something in the works...
Regards
Ed
Regards
Ed
hey dose an A on the front and B on the back give u 1 degree of toe in the
rear?
rear?
If you go to Ed's site he has a list of what the diffrent toe blocks do.
http://www.thard.co.uk/excel/ToeBlocks.xls
do u have an place that u dont need excell to read the link
so a - b would be a 1/2 degree of toe.
a - c would be 1 degree of toe
thanks alot thats all I need to know and it was much easyer then to dl excell
to read it
to read it
Originally Posted by tamiyarcracer
in a nut shell each block is 1/2 a degree
ya i know that, by the way do u know what the TAO5R rear hubs are, they
are not metal
are not metal
are not metal
are not metal
Super Moderator
Originally Posted by Grizzbob
Actually, you don't need to download Excel to read those files, Microsoft's site has a smaller application that can view those files, though you can't change them, but viewing & printing them out works fine). Just check out their site to find it.....On another note, I have a small problem of my own, for running on asphalt, I picked up the aluminum front ball diff kit(I also have the spool, but Ireally don't like using them, & the one-way doesn't feel right to me on parking lots, I tried & it didn't work too well), but when I tried installing the diff, I couldn't get the stub axles to fit without bumping against the plastic "T" nut(couldn't even snap on the camber link on that side). Now I have the 46mm axles, & am running the 1B & 1A blocks up front, & I also tried the 42mm axles, but they wouldn't even reach the outdrive cups at all, so I was wondering if anyone had any ideas on how to deal with it?
Super Moderator
Are you sure you put the screw and thrust bearing on the proper side of the diff?
I think the plastic ones are 1 degree per side.
cheers,
al
Hi guys,
Just to let you know, yesterday I have partecipated to the second round of the BRCA mod nationals (ran in 5-cell mod). Qualified 15th and won the second leg of the final (after a mechanical failure of my 3.5T in the first leg) to finish 2nd in the B overall.
All the week end the car was fantastic, I will make an editable PDF of the MSXX setup sheet and post my setup.
EDIT : I have now attached a Jpeg version of the setup, anyone wanting a PDF PM me.
