Tamiya TRF415
hej guys
i got the ta05 pulley's, but the front pulley is 3mm thick and the original msx one is 1.5mm
where should i get rid of the 1.5mm ?
thanks
btw is there anything more i should know about modifing to the ta05 pulley's ?
thanks
Originally Posted by freekthefreak
hej guys
thanks
thanks
Originally Posted by trf_racer
Are you using Front One-Way? If so, you can get the MRE one-way housing, so you don't need to do any modification.
i'd rather modify the pulley or something then by a front-way housing for 32$
hmmm.
thanks
its fixed
its fixed
pinion size
I like to know what is the pinion size that should I use with my trf415 msx mre.spur gear is the one that came with the kit.also what is the pitch
hmmm.
pinion
yes, the motor is stock trinity co27 an the track is asphalt
37,38 It should be at 6.3fdr
pitch
ok 37 or 38 tooth at what pitch? 48 or 64 pitch?
64
Hi Guy's
Is there any difference between the TA 05 wide pitch pulleyand TA05 normal pulley, its just that a rock went into the pulley and distroyed the back one. I know the pitch is different but are they still both 36 teeth and is it okay to run a wide pitch at the front and a normal TA05 at theback. I will have to order a couple of spares after christmas.
Thanks Guys
Addam
Thanks Guys
Addam
