Tamiya TRF415
well, MSXX looks good... but I'll just be getting the parts to stick on my MRE separately
Originally Posted by stuey
what look new on the lower deck
Originally Posted by trf_racer
The extra holes beside the suspension mounts. Also, to use the new bumper, the chassis must be shaped differently too.
415's in cleveland?
So any of u guys heading to the cleveland indoor champs? Wouldnt mind seeing a greater attendance of tamiya's!
Originally Posted by Tsquare
I would wait for the MSXX - I still have my MSX, didn't build the MRE - had a feeling a new car would quickly follow - I will be buying a MSXX for the 2007 Race Season.
Corey good to see you on here now also.
Garber
Originally Posted by JRRobiso
Based on the picture. Looks like a new topdeck, alum airduct, one way units, reg screws, TBEvo5 foam bumper & bumper brace(??). Not sure about the foam bumper & the brace.
Originally Posted by buboy28
please forgive my ignorance but what is an aluminum airduct and what does it do
There is a hole cut out at the below the chassis & there will be a alu airduct which gives a diffuser effect to suck air from under the chassis to the motor. Basically is cooling for the motor.
The MSXX upper deck looks funny... And the lower deck is 2.5mm, so is thinner than the MRE which is 3mm, if I'm not wrong.
Looks like I might just get the airduct & the one-way (just as tunning option)...
oh ok thanks, already have the MRE so might go with the airduct also
I'm getting the airduct so that my ESC have a fuller area to seat on...
[QUOTE=Ben.C]The MSXX upper deck looks funny... And the lower deck is 2.5mm, so is thinner than the MRE which is 3mm, if I'm not wrong.
[QUOTE]
Think the MRE is 2.5mm as well... but I haven't measured it, so can't be certain. Something to check tonight.
[QUOTE]
Can someone with a MRE please post the part numbers for the steering system and also the rear heatsink bulkhead.
I am trying to get RC-Champ to order the parts for me.
Want to try converting my MSX to MRE minus the internal ratio change.
So far, these are the part numbers I can find:
Steering Arm #9808066
Steering Post #9804266
Steering Bridge # __________
Rear Heat Sink Bulkhead #__________
Upper Deck #4024004
Lower Deck (Chasis) #9404668
Alumn. airduct thingy # __________
If you guys can help me fill in the blanks, that will be great.
Cheers.
Upper Deck #4024004
Cheers.
Steering Bridge #3454396
Rear Heat Sink Bulkhead #3454404
Upper Deck #4024004
Alumn. airduct thingy #not available yet
Cheers.
Upper Deck #4024004
Cheers.
