Like Tree3Likes
Tamiya TRF415
Old 10-29-2006, 12:44 PM
  #16246
Turbonium's Avatar
Trader Rating: 27 (100%+)
here is a project i decided to try out... running rubber/carpet.
basically, i used the bottom plate from my MRE and installed the MS bulkheads... the idea of keeping the 1-pc bulkheads, but trying the hewer style steering.
probably wont be able to test till next weekend...
Attached Thumbnails Tamiya TRF415-dscn0522.jpg   Tamiya TRF415-dscn0523.jpg   Tamiya TRF415-dscn0524.jpg
Turbonium is offline
Old 10-29-2006, 01:01 PM
  #16247
Trader Rating: 21 (100%+)
Default WOW!
This car is Awesome!Finally ran it today.Having to use a comprimised setup a bit...Kit parts with foam.Still....Tryhard,Yes it steers like mad but,without loss of the back end.Couple of tweaks and the thing is rocking.Got the front diff in today too but,with the locked front end working like it is....Can't wait till I get the carpet bits now.If it's this good now...O.K.,rant over with.lol.Mario.
lotus1 is offline
Old 10-30-2006, 05:54 AM
  #16248
jtracker's Avatar
Trader Rating: 28 (97%+)
Hey,
I am looking to buy a tamiya 415 so thought I would post in here and see if anyone was wanting to sell theirs or maybe know of one thats for sale. Thanks,
Justin
jtracker is offline
Old 10-30-2006, 07:33 AM
  #16249
JRRobiso's Avatar
Originally Posted by jtracker
Hey,
Justin
I'm planning to sell my 415 w/ alot of upgrades with it. Send me a PM if you're interested or emial me @ [email protected].
JRRobiso is offline
Old 10-30-2006, 06:45 PM
  #16250
hierog's Avatar
i've got an NIB MRE if you're interested. PM me
vic
hierog is offline
Old 10-31-2006, 12:31 AM
  #16251
SpeedTech's Avatar
Hi Guys,
We added a new section for the TRF415MRE parts. We should get more parts in soon
Steve Wang
SpeedTech is offline
Old 10-31-2006, 01:59 PM
  #16252
WRXTC's Avatar
I have just ordered part number 49358 from rc_champ. I have now heard that the Tamiya Spool is garbage? is this correct? and do I need anything else to install the spool? Like a centre pulley?
http://www.tamiyausa.com/product/ite...oduct-id=49358
It looks like it is decent quality other than the plastic outdrives?
WRXTC is offline
Old 10-31-2006, 02:02 PM
  #16253
Charles Godwin's Avatar
Running the tamiya spool seems fine to me i've maybe ran 3 meetings on my MRE spool and it's holding up fine. When i ordered my spool i had to order a front one way pulley. You might want a pair or two of derlin outdrives just incase you break them.
Charles
Charles Godwin is offline
Old 10-31-2006, 02:08 PM
  #16254
WRXTC's Avatar
I also ordered part http://www.tamiyausa.com/search.php?...x=18&image.y=7
I hope this is the right pulley? I have an MSX. If not the parts were very cheap anyway so it's no real big loss, just means I will have to place another order sooner rather than later
I guess it's not the right pulley anyway, I can use the pulley from my one way that's on the car now untill I order a new pulley?
WRXTC is offline
Old 10-31-2006, 02:13 PM
  #16255
That's the centre 1way pulley (pulley by the spur gear), you need a front one way diff pulley. Haven't got the part no. on me but you can always look on speedtechrc's website to get the part no.
Charles
Old 10-31-2006, 02:24 PM
  #16256
WRXTC's Avatar
https://www.tamiyausa.com/product/it...oduct-id=51054
I believe that's the part you are referring to. As I have a one way already on the car, once I remove the one way I am sure I can take it apart and use the front one way diff pulley that came with the kit. Please correct me if I am wrong so I can go into panic mode and try and find one asap!!!
WRXTC is offline
Old 10-31-2006, 03:39 PM
  #16257
TryHard's Avatar
Thats correct. The front one-way and spool use the same pulley.
BTW, if you want some tougher outdrives, the TA05 spool comes with steel outdrives that are a perfect fit...
Personally though, I never found the durability a problem with the delrin outdrives outdoors.. it was only when using it indoors (which is very rare, as I normally use a 1way) that I found it too be a problem.
HiH
Ed
TryHard is offline
Old 10-31-2006, 03:57 PM
  #16258
R/C Tech Elite Member
JayL's Avatar
the MRE uses a different front spool center section than the 415 one posted, and the alum sleeves help alot
JayL is offline
Old 10-31-2006, 04:11 PM
  #16259
WRXTC's Avatar
I am running an MSX not an MRE so I think everything is sorted with the parts that I have ordered and the pulley I already have and I also run outdoors on Tarmac or asphalt so durability shouldn't be a problem. I am not running Modified it will be mainly for stock or 19 turn. so I think I shouldn't have any issues.
Cheers for the advice guys.
WRXTC is offline
Old 10-31-2006, 05:02 PM
  #16260
TacticalTimbo's Avatar
Default Drilling a body
I'm finding it impossible to drill a shell for my TRF415, its a pre-painted Hot Works 350Z and as its a universal shell there are no marks! I tried putting paint on the top of the posts but it is impossible with the human hand to get it perfect first time and therefore it ends up smudged and useless. I also thought of laying the shell next to the car and measuring across but it is hard to tell if the shell is lined up straight next to it, plus there are loads of nasty measurements to take.
So my question is what's the best way to drill the shell correct?
TacticalTimbo is offline
