Laying Carpet
Old 12-20-2008, 10:06 AM
SoCalMitch's Avatar
Default Laying Carpet
Can carpet be laid down right on top of a concrete floor or does a wooden sub-floor need to be built?
SoCalMitch is offline
Old 12-20-2008, 10:24 AM
MAD916's Avatar
RC plus in Salem Or, had glued their carpet directly to the concrete slab worked great and lasted almost 7 years. The only thing they see with that is that traction really changes with the weather since the slab temp changes.
We choose to take the route of laying it and glueing it down to a 3/4" T.G. sub floor. what we see is great traction and the carpet temp come up almost as fast as the building temp. our is up on 2"x4" under the subfloor to allow for air flow and uneven surface below.
Makes for a Killer Sound.................................
MAD916 is offline
Old 12-20-2008, 11:28 AM
RCSteve93's Avatar
My local track has a asphalt sub floor. It can be done.
RCSteve93 is offline
Old 12-20-2008, 11:36 AM
2056dennis's Avatar
Trader Rating: 134 (100%+)
Default carpet
yes it can be and you can use double face tape to hold it in place BUT DONT BE SCARED TO USE ALOT OF TAPE when we did Josh Cyruls track we put 5 rows of tape per seam and it held up great
2056dennis is offline
Old 12-20-2008, 12:07 PM
u can put the carpet to the concrete but its better being on a sub floor. helps with grip and traction.
wait a minute is offline
Old 12-20-2008, 12:33 PM
SWTour's Avatar
The Carpet track up in LINDSAY CA, lays the carpet out on a gym floor that is covered with those 12" x 12" interlocking plastic floor tiles.
The floor doesn't feel the effects of the temperature the way it would on straight concrete.
This isn't a permanant facility though, the carpet is only laid out when there are races.
If the place is not having to be torn down and set up, and a SUB FLOOR is in the budget...but all means SUB FLOOR, it makes the tracks AWESOME...but if budget is a concern, ANY Carpet is pretty much better than NO carpet!
SWTour is offline
Old 12-20-2008, 07:52 PM
robk's Avatar
Trader Rating: 22 (100%+)
A sub floor is not a must, but it should be handled properly if you go that route. If not, you will have ski jumps on the back stretch. Find a good carpenter
robk is offline
Old 12-21-2008, 05:44 AM
Gain Time's Avatar
If you choose to glue straight to the concrete be sure to inspect the concrete for dips and cracks. Fill them before you lay the carpet or you will also have pot holes so to speak.
Gain Time is offline
Old 12-21-2008, 11:20 AM
MAD916's Avatar
We used Tounge and Groove sub-floor and then also used a biscitt jointer on the 4' end of the floor. to keep the seams flush. then hand sanded and filled with joint compound (192) sheet's........
Also we laid out roofing felt paper down on the asphalt before we laid out the 2"x4" and sub floor.
well worth all the extra work
MAD916 is offline
Old 12-21-2008, 01:19 PM
robk's Avatar
Proper!
robk is offline
Old 12-21-2008, 06:00 PM
beyondthepack's Avatar
Holy cow dude thats gunna be a naaaaaaaaaaaaahhhice size track when ur done, props to ya
beyondthepack is offline
Old 12-21-2008, 06:05 PM
RCSteve93's Avatar
Jeez. Nice track. I bet you can hit 50 on the straight with a 17.5.
Old 12-21-2008, 06:25 PM
MAD916's Avatar
Thanks guys... All done been a up for a year now..... have another big race in Feb 14- 16th.
info and photos at: www.timezoneracing.com
MAD916 is offline
Old 12-21-2008, 06:28 PM
revo523's Avatar
Not trying to highjack this thread, but how necessary is it to use the carpet made for in door tracks? Can i use regular commercial carpet?
revo523 is offline
Old 12-21-2008, 06:59 PM
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
pretty interesting thread. prolly somethin RC folks dont see much of. track building. its surely somethin that our friends over in the slot car world have on us. then again most of them are retired and have plenty of free time heh
R
UltegraSTI is offline
