Xray M18
Old 03-03-2005, 10:07 AM
  #646
duneland's Avatar
Good luck! The motor is mounted too high with the alum Xray mount! I can't imagine tring to get around a corner with it mounted over the drive shaft.
duneland is offline
Old 03-03-2005, 02:36 PM
  #647
Drew_Cat's Avatar
i was thinking the same ..... i'll have to run it and see....
if the only issue is roll in the corners, that should be easy to correct.( sway bars... )
Drew_Cat is offline
Old 03-03-2005, 03:23 PM
  #648
I've been running the vert motor mount for ages.... No roll probs. Handles speed 30-35mph as good as my 1/10th...
havy
havy is offline
Old 03-03-2005, 03:29 PM
  #649
Drew_Cat's Avatar
havy
can you share you set up for carpet?...thanks
Drew_Cat is offline
Old 03-03-2005, 03:44 PM
  #650
Sorry, no carpet tracks over here. I only run onroad asphault and on big 1/10th scale tracks at that. But personally, I can assure you that you won't experience any more traccion role than you would w/ the other set-up. I personnaly find the best balance is w/ the vert motor mount. I put the controller under the drive shaft w/ saddle pack at either side. For on road I run Magenta TRC foams full uncut donuts 20mm rear on homemade rims and 17mm fronts on rear rims (custom glued) and untrued. The stance is a little wider but the car makes turns as fast, no role. Ride hieght is adjusted to be 3-4mm w an added spacer to the rear spings to keep the car a little higher for clearance on these larger, not perfectly smooth tracks. But I'll run it against a custom carpet track setup car w/o worrying about performance. The car handles as good or better than my Kyosho FW-05R. Almost as fast too. I run a Razor Micro car motor and 36t spur w/ 21t pinion. Really is a fast set-up. I was one of the origional beta testers for the Mamba, and ran the Beta version untill the other day. Awsome controller, your going to like the set-up. BTW, your car looks real nice, enjoy.
Good luck,
havy
havy is offline
Old 03-03-2005, 04:47 PM
  #651
Steve Bahnatka's Avatar
Drew_Cat, where did u get your chassis?
Steve Bahnatka is offline
Old 03-04-2005, 04:26 AM
  #652
Bobby Z's Avatar
Default Pic of my cars
Here are my Team Hammer Chassis M18's ready for a battle this weekend in Western New York.
Bobby Z is offline
Old 03-06-2005, 11:11 AM
  #653
duneland's Avatar
I guess it all depends on where you are running... At my track you would not be able to make your car competetive with the motor over the shaft. I am making a new mount for my car, that will put the Mamba motor flush with the bottom of the chassis. This will allow a little more corner speed before the inside tires begin to lift off the surface. We are already running sway bars, or in my case, a suspension that is very stiff and allows for very little chassis roll. I run 2mm or less ride height. If you are running with less lateral grip, or at lower speeds, then the 'over the shaft' mount looks more attractive.
duneland is offline
Old 03-08-2005, 05:44 PM
  #654
Drew_Cat's Avatar
Ask for Vito Catalfamo of NYC Hobbies tell him Drew send Yah !!!
Drew_Cat is offline
Old 03-27-2005, 08:54 PM
  #655
where is the best place to get parts? i will be getting a m-18 in a ouple of days
Nathan is offline
Old 04-01-2005, 09:07 PM
  #656
still wondering
Nathan is offline
Old 04-01-2005, 10:46 PM
  #657
lazyboy's Avatar
www.rcraceday.com
lazyboy is offline
Old 04-02-2005, 03:13 AM
  #658
Xtant3150c's Avatar
Have you guys seen the new EITS XGT Pro chassis?
XGT Pro
Xtant3150c is offline
Old 04-02-2005, 09:26 AM
  #659
tony montana's Avatar
Trader Rating: 76 (100%+)
I have one of those chassis but it is dark gray carbon. If anyone is looking for a m18 with the optional blue xray chassis and xgt chassis and a brand new noval spy Im selling it all for 200.00. Also has the power pack as well
tony montana is offline
Old 06-24-2005, 08:13 AM
  #660
i want to get an xray m18 to race on a small carpet track. what do you guys suggest as far as esc? the mamba? is the mamba as good as novak or tekin? also, it is a small carpet track, do you think the competition x is too much power for this? thanks.
Joe Chaplow is offline
