Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 09-07-2015, 03:12 PM
  #8761
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Gillblade
What are the biggest difference between the Evo and the EvoII in handling? Raced a A700 Evo last year for 3 races (borrowed car)and I loved how that car handled, and now I have ordered a new EvoII with Alu chassie...
3 big changes-
D2 shocks allow you to adjust pack with oil and impeller changes
S2 (and S) alloy chassis allow for massive flex changes due to the am30/33 chassis braces
Mm2 motor mount allows for rear end chassis flex adjustment
hanulec is offline
Old 09-07-2015, 06:47 PM
  #8762
nexxus's Avatar
Trader Rating: 315 (100%+)
Finally started some real set up changes on my car (A700 EVO with MM2) and noticed that if the centre brace bar thing is tweaked it really throws out the front gear box, loosened it up reset, screw back down, fixed! Also the bottom screws on the outer hubs went for a walk, no wonder I couldn't get a ride height over 5mm! (I need 6-6.5 for our track)
How is everyone measuring droop? I am used to downstep blocks and guage, but can't really see how that'd work here as disconnecting the shocks wouldn't be as easy as say a T4
nexxus is offline
Old 09-07-2015, 07:33 PM
  #8763
hanulec's Avatar
blue loctite is your friend. i put a TON of it onto-
- MM2
- ST03 balls going into the AM06{ms}
- 2.5mm screws into the FFG
- 3mm screw going into the AT20 holding the G03 on
for droop -- this has been asked a TON of times
#1 euro way
http://www.rctech.net/forum/14031113-post8464.html
http://awesomatix.info/en/tipps-tric...es-awesomatix/
#2 usa way
http://www.rctech.net/forum/14117053-post8589.html
hanulec is offline
Old 09-08-2015, 05:11 AM
  #8764
RC Professor's Avatar
Trader Rating: 17 (100%+)
Hanulec - Any idea when the D2.1-S dampers and RFG will be back in stock? Thanks.
RC Professor is offline
Old 09-08-2015, 05:12 AM
  #8765
hanulec's Avatar
Hopefully this week. They are in the air right now..
hanulec is offline
Old 09-08-2015, 06:12 PM
  #8766
i just received a used EVO and found the installed at12m has the bolt's head snapped off. anybody have any ideas how i can take it off without damaging anything else, i can still use the at12 included.
voodoo is offline
Old 09-08-2015, 07:49 PM
  #8767
hanulec's Avatar
Try holding the spur and spinning the at12m counter clockwise
hanulec is offline
Old 09-09-2015, 03:58 PM
  #8768
ah, done. thanks hanulec. first time to try the car last night and everyone who tried including me was blown away, on power steering is awesome! can't wait to read more and tune it to our local track.
voodoo is offline
Old 09-09-2015, 04:23 PM
  #8769
skypilot's Avatar
Trader Rating: 14 (100%+)
Is there a page with carpet setups on it?
skypilot is offline
Old 09-09-2015, 04:44 PM
  #8770
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Here ya go Skypilot
http://www.petitrc.com/reglages/awes...ixA700Evo.html
OVA is offline
Old 09-09-2015, 10:30 PM
  #8771
bkspeedo's Avatar
http://www.awesomatixusa.com/p/setup-sheets.html
These are all US setups, most are for Carpet.
bkspeedo is offline
Old 09-10-2015, 12:49 AM
  #8772
Schwarta's Avatar
Anyone have a good setup guide? I've got the Hudy one, but the car has a lot of adjustments that isn't in there?
Schwarta is offline
Old 09-10-2015, 09:26 AM
  #8773
skypilot's Avatar
skypilot is offline
Old 09-10-2015, 10:21 AM
  #8774
hanulec's Avatar
There are some good tips here--
The major point of difference between any Awesomatix car and other 4wd TC are--
Shock
Springs
Reactive caster
Dynamic Rear Toe
Recent chassis with longitudinal chassis stiffeners
A lot has been published but might not be easily found in one place. If you have a topic in question please ask. We will do our beat to answer/provide guidance
hanulec is offline
Old 09-12-2015, 06:07 PM
  #8775
Default Questions about C01-AL Chassis for A700L
I currently have an A700L with a carbon chassis and run it in USGT.
The tracks I drive on are low-medium grip carpet.
I have a couple of questions:
1. If I am to change the chassis to the Aluminum Chassis (C01-AL) is the center support for the drive shaft that has 2 bearings necessary to have if converting?
2. If it is necessary, what part number is it?
3. What kind/ type of handling characteristic changes would I see going from carbon to aluminum?
Thanks,
Brian
Aquaracer is offline
