Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 01-05-2014, 06:27 PM
  #5131
cwoods34's Avatar
Originally Posted by hanulec
That is great news... and I cannot believe the price. Hum... so many things to consider...
Any suggestion for alternatives to XRay:
964050 big washers
964031 small washers
There are a lot of folks looking for Side Pieces these days -- which is what started Side Piece Racing...
Here's the shims for the diff (Also fit perfectly).....
http://www.vbcracing.com/collections...ials-shims-set
cwoods34 is offline
Old 01-05-2014, 06:46 PM
  #5132
Damn, wish I had some help in that area. I'm the only unsponsored driver to shuffle the podium with you sponsored folk!
Boostinswifty38 is offline
Old 01-05-2014, 09:22 PM
  #5133
Trader Rating: 24 (100%+)
Hey guys... Putting together my evo... This might be a dumb question, but since the shock assembly's on the front and back of the car mirror each other, how do u put the right shock on the right side on both the front and back when they are fitted properly into Part AM17? Should they not be opposite on the front and rear of the right side as well as the left?
Also, one of the SPR02 parts doesn't seem to Slide in far enough to 1 of the 4 shocks for me to secure it with a set screw? Anyone else had that issue?
gocoogs is offline
Old 01-05-2014, 10:12 PM
  #5134
Because of the tight machining you have to sometimes wiggle Spr02 left to right in the slot so it will slide through.
Turn the chassis around as you assemble and it will magically become the proper left and right side when viewed from that end of the chassis
Difuser is offline
Old 01-05-2014, 11:51 PM
  #5135
SPR02... Gotcha..
Turn the chassis around? Seriously? Now that's funny... Are you messing with me? Ha
gocoogs is offline
Old 01-06-2014, 03:25 AM
  #5136
Originally Posted by gocoogs
Hey guys... Putting together my evo... This might be a dumb question, but since the shock assembly's on the front and back of the car mirror each other, how do u put the right shock on the right side on both the front and back when they are fitted properly into Part AM17? Should they not be opposite on the front and rear of the right side as well as the left?....
Please see the picture and note for STEP 9 ( p.11 ) of the Instruction manual.
Every DR6 should be installed into AM17R holder (on the first picture of STEP 9).
Every DL6 should be installed into AM17L holder ( the part that is mirror symmetrical to AM17R).
Oleg Babich is offline
Old 01-06-2014, 04:56 AM
  #5137
Ok, I guess I thought R6 damper referred to as the "right damper" in the manual should actually go on the right side of the car when installed. In reality however, only one of the two right dampers actually goes on the right side of the car... The other right damper goes on the left side! Got it! Clear as Mud! Why wouldn't they explain that in the manual? Or label the shocks FR for front right or RR for rear right etc?? Oh well, the car looks awesome, the instructions could sure be enhanced with some additional explanation in certain areas!
gocoogs is offline
Old 01-06-2014, 04:59 AM
  #5138
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
SPR02... Gotcha..
The suspension is identical front and rear.
Hopefully you'll have more luck when applying setup to the car.
Where will you be racing?
hanulec is offline
Old 01-06-2014, 05:49 AM
  #5139
Houston! I'm justin Cornett...got the car from u.. Racing at RSD speedway.. Christian Tabush's track. Thanks for the help!
gocoogs is offline
Old 01-06-2014, 06:54 AM
  #5140
Justin, you'll love the car when you get it on the track. There's a few items you have to pay attention to on the build but it all goes together very well. Once you get the idea of how to adjust the chassis, small changes are easily felt.
Difuser is offline
Old 01-06-2014, 07:08 AM
  #5141
Travis S's Avatar
Trader Rating: 46 (100%+)
Hanulec, Gee, and Hoff what servo savor are you guys running (a part # would be great.) Had some issues with my tamiya one last night not centering and I want to replace it with something better.
Travis S is offline
Old 01-06-2014, 07:19 AM
  #5142
bkspeedo's Avatar
XRAY X-Stiff Composite Servo Saver Set
http://www.amainhobbies.com/product_...ervo-Saver-Set
bkspeedo is offline
Old 01-06-2014, 07:38 AM
  #5143
olhipster1's Avatar
Trader Rating: 102 (100%+)
It all becomes clearer after a few drinks of vodka. .
Take your time when building the gear diff the first time....must be done precisely....and the car will be awesome.
olhipster1 is offline
Old 01-06-2014, 07:57 AM
  #5144
Travis S's Avatar
Thanks! I will get that then. What hole out of the 6 do people use. RCTech is failing and not letting me use the search in this thread because I am sure that info is out there.
Travis S is offline
Old 01-06-2014, 08:02 AM
  #5145
thanks... im sure i will. having a little trouble reading the set up sheets properly... i dont really understand how the upper camber link positions translate to the car... to me it doesnt seem like there are as many upper camber positions as are listed on the set up sheet... for example.... like in the rear it shows 5 options, but on the car, there are only 4 spots... again, i might be missing something, but its confusing.
im excited about the car! it really is a piece of art!
gocoogs is offline
