Awesomatix EP Touring Car (A700 Shaft Drive)
#4471
I'm putting Larry's latest setup for my next outing at MRH. Can you guys confirm that you are using the stock AT21 pivot balls? I ask because I've changed out to the Xray ball studs and would need to to adjust the shims accordingly. I recognize the use of AT21S for the lower arms.
#4472
#4474
0.5mm is the height difference between AT21 & AT21S...
#4475
R/C Tech Elite Member
http://shop.awesomatixusa.com/caster-doodle.html
more pics to be added later... off to IIC open practice in 30m
#4477
Just got my carbon fiber shaft made be ewippler installed. Here is a video of me doing full throttle/breaks etc to see if the shaft has any flex. Looks like it will work out great. Less overall weight and a stronger shaft lets me take out that center brace for even less drive train friction. BTW - I know some people are testing this in mod without the center brace and have said it has worked fine so far.
http://youtu.be/hT2TlR5zALM
I would turn down the volume that close to the drive it's a little noisy.
Here is the thread for the shafts btw http://www.rctech.net/forum/electric...g-cars-31.html
+ YouTube Video | |
#4478
Hi all,
Ive noticed a big amount of play between the becel gear and the diff gear. So heres my question: How many shims did you add at the bevel gear?
#4479
I think the setup that Hanulec and I came up with works pretty well. After practice is over for 17.5 TC at the IIC here are the standings.
1) Michael Hanulec 29/5:00.567 (R4)
2) Bradley Johnson 29/5:07.264 (R3)
3) Kyle Bergstrom 29/5:07.622 (R3)
4) Devin Patterson 29/5:08.295 (R4)
5) Bill Sydor 29/5:09.442 (R4)
6) Eric Anderson 29/5:09.519 (R4)
7) Justin Salerno 29/5:10.978 (R4)
8) David Zorn 28/4:59.862 (R4)
9) Cody Woods 28/5:01.504 (R3)
10) Michael Herald Jr 28/5:02.588 (R2)
11) Arthur Scrimo 28/5:03.086 (R3)
12) Robbie Michael 28/5:03.214 (R3)
13) Monti Panzica 28/5:04.565 (R4)
14) Brian Wynn 28/5:05.237 (R3)
15) Blake Keulen 28/5:08.161 (R4)
16) Zdenko Kunak 28/5:08.384 (R4)
17) Craig Xavier 28/5:09.045 (R4)
18) Cory Parsons 28/5:09.079 (R3)
19) Brent Klingforth 28/5:12.404 (R4)
20) Arvin Nano 27/4:52.250 (R2)
#4484
Go get 'em guys !!!
