Awesomatix EP Touring Car (A700 Shaft Drive)
#2671
Hey guys, I´m using sweep 28 wheels and trying to figure out some setups...
-main problem is that all the setups I found use 3 or 2.75mm under the P01/P02 . But anything over 2.5mm and they rub on the wheels.
Any advice how to modify some setup that has 3mm and if I use 2.5mm what do I need to change also to make it work?
High grip carpet, same track that is on this setup from Viljami(he uses the A700 car so maybe the P01 is lower on his car then on A700L ? ) :
http://awesomatix.com/download/ -> "New setup from Viljami Kutvonen"
any help is appreciated since I´m new to all this setup stuff.
-Pate
-Pate
Please use a sharp hobby knife.
It will give you the desirable 0.5mm for smaller wheels.
2. You have possibility to remove 0.5mm or 0.75mm under outer upper ST03 ball studs and at the same time to remove the same amount of mm under inner upper AT21 pivot balls on this suspension.
It will give you almost (very very close) the same roll center position and camber gain.
Thanks, erchn, you was first with this comment.
3. Please note that Viljami's latest setup uses AM26/AM06S combination on the rear.
AM26 shifts P01/P02 out of wheel.
#2672
Thanks erchn and Oleg for your very informative replies!
I will try first cutting small bit off the P02 so the setups are easier to copy.
-Pate
-Pate
#2674
Oh, and maybe cause I edited my prior post you missed one question:
Is lubrication needed for the steel gears?
If so, what would you use, something dry like graphite or what?
#2675
You can use any dry lubricants or grease designed for metal gears.
#2676
caster tool on hudy setup..
that's homemade parts to help setup the caster on 4 ends at the same time
on Hudy setup tool.
on Hudy setup tool.
#2677
I still have the ones from my A700. If they are the same as what is currently offered as an option....
AT26 is 16.4mm tall and its diameter is 6mm, ( roughly 7mm on the knurled section )
P21S is 3.2mm tall and 14.47mm in length. Swing from the center of the screw is approximately 10.5mm.
Cheers,
Jake D.
#2680
Hi Ethan,
Cheers,
Jake D.
Cheers,
Jake D.
Thanks, Jake.
#2681
#2682
#2683
I like your parts method...
#2684
