Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 02-06-2012, 10:06 AM
  #1546
erchn's Avatar
Originally Posted by TryHard
Hi Freddy,
Setting attached.
Main differences between this and your warmup one...
  • Dampers/Springs are set harder, with 2.0mm F&R added to the A value.
  • Front damper is set up with Option II SRS/RHS, but if go to 0/1 (A/B) on that damper setting (now at 2/1) gives the same spring rate as Option I at 0/5.
  • Fully cut top deck (I haven't figured out how to re-glue it back together )
  • Different rear diff oil (Losi90 ~1200wt)
  • Didn't use the extra motor mount screws
  • Different Tyres (Sorex28's)
HiH
Ed
Is that really positive 1 degree of toe up front, or negative 1?
erchn is offline
Old 02-06-2012, 06:27 PM
  #1547
TryHard's Avatar
Originally Posted by FreddySudhoff
Ok thanks! I think a big different thing is the surface. You drove on asphalt and I on carpet :P
Hi Freddy,
Yup, don't disagree on that at all! My plan has been to try and get a good geometry setup, then tweak the springs/dampers/bars to suit the surface... so far on the right path, should give a good base setting for Thailand.
It's interesting that going softer for carpet seems to be the thing of the moment... had the same with the 417.
Cheers
ed
TryHard is offline
Old 02-06-2012, 06:28 PM
  #1548
TryHard's Avatar
Sorry, should be 1deg toe-out... so negative.
TryHard is offline
Old 02-06-2012, 11:21 PM
  #1549
You were right with positive. Negative would mean toe in. oops
Mb3195 is offline
Old 02-07-2012, 01:31 AM
  #1550
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Toe
Owen RaCing is offline
Old 02-07-2012, 09:10 PM
  #1551
jake95's Avatar
Trader Rating: 27 (100%+)
hi,
i was wondering if any of you use lubrication on the drivetrain if so what are you's using.
jake
jake95 is offline
Old 02-07-2012, 09:54 PM
  #1552
TryHard's Avatar
Originally Posted by jake95
hi,
jake
I'm using a light coating of Losi ceramic greese in the gearbox, and a light oiling on the CV's joints. Thats it.
HiH
Ed
TryHard is offline
Old 02-07-2012, 09:58 PM
  #1553
jake95's Avatar
HiH
Ed
thanks Ed i will try and find some ceramic grease then.
jake
jake95 is offline
Old 02-07-2012, 10:26 PM
  #1554
Magnet Top's Avatar
Originally Posted by MDawson
Post race - Sub-100 dampeners with the Jaco Blues feels too soft, too much chassis scrub.
Hey Mark,
Thanks for the notes from the "Birds". Yeah, I'm finding it difficult to go too far below 100 gf/mm too but I've been mainly racing with Sweep 32 spec tires on newer ozite carpet. Come to think of it I raced once with the Sweep OG tires at Timezone II raceway and going softer helped but the traction there is high so it makes sense. Hmmm..... Too many variables with different carpet, different tires, different traction compound. Yet I am still puzzled with Freddy's very soft settings on medium traction carpet. He beat Ronald with it... so I'm not disagreeing with it !
Jake D.
Magnet Top is offline
Old 02-07-2012, 10:56 PM
  #1555
erchn's Avatar
hi,
jake
Dry lubricants work great on the gears. Something like this. I also use black grease, AE or Xray for the CVDs.
Ethan
erchn is offline
Old 02-07-2012, 11:01 PM
  #1556
jake95's Avatar
Ethan
hi,
ethan thats what i was thinking of like dry chain/gear lube.As i would think a normal lube will not be able to stay intact with the gearbox properly.
jake
jake95 is offline
Old 02-08-2012, 05:15 AM
  #1557
Originally Posted by Magnet Top
Hey Mark,
Jake D.
The soft setup is the current thing. The faster cars at Snowbirds all seem to drive on their 'nose' a little bit. Guys are chasing after Yokomo springs to get that Volker-esqe setup.
The setup works well for the classes with more power. I thought the deadened front end was too soft for 17.5 class but felt more at home with boosted car.
Like most setups - there are a lot of variables. But the setup is in the ball park. The Snowbird tires were really inconsistent. You could have pulled 5 sets of tires and 2 sets would have felt the same.
It has been sunny here of late. Hopefully we can get started with our outdoor season early. Anxious to get some asphalt time with this car.
Good thing is there are many ways to get quick with this car.
Any car can win on any Sunday. This past weekend Xray was tops of the field. Mike Haynes looked strong in Expert and Stock while Hagberg checked out on the field in Mod.
MDawson is offline
Old 02-08-2012, 06:03 AM
  #1558
defcone's Avatar
Trader Rating: 15 (100%+)
Do u know what happened to Naoto?
defcone is offline
Old 02-08-2012, 06:05 AM
  #1559
Team EAM
Trader Rating: 79 (100%+)
He Blew out in every class he ran
EA
EAMotorsports is offline
Old 02-08-2012, 06:10 AM
  #1560
The missed it when it happened. He got shufffled out early in the first corner and then dropped out. The video is on the Snowbirdsnationals.com website. I think it is Video4.
It has been a while since I have seen someone check out like that in the mod main. Hagberg had the total package.
MDawson is offline
