12th Scale Setup Station
#16
Sorry for the delay...work has been crazy. Anyway here are pics of the setup station Holeshot used to make. As you can see the system was very simple to make and easy to use. Because it uses a block on the front axle you get much more accurate adjustments over using the rim. The blocks also had a line etched in them so you could use the RPM gauge to measure caster as well.
#18
Yeah...now that pan cars are back I'm glad I didn't get rid of mine
#20
Wanting one of these for 1/10 ...who has one...
#21
