XRAY T2’009
#1156
Trust me on this one, I sell this stuff for a living. The blue is good but rated for larger fasteners (1/4" to 3/4" with about a 180in/lb torque breaking point).
The purple is specifically designed for fasteners under 1/4", brass, aluminum, etc. The breaking point is about 53in/lbs.
#1157
#1158
@ Nexus Racing,
I have the US foam spec and multi-diff...I wanna get the ECS drive shafts...what length do I get (50 or 52mm)? I think i read in the xray forums that an EU rubber spec w/multi-diff will need the US 50mm ECS as 52mm ECS will be too long coupled w/multi-diff in an EU...true or false?
Sometimes with aluminum the threads can be stressed. When some types of lock tight are used and for the length of time it has been set. The threads can pull out. I believe this also depends on the quality of aluminum that is used.
#1159
@ Nexus Racing,
50mm !
#1161
http://www.piez0r.com/Skiddins/Xray%...etup%20Sheets/
#1163
does anyone know from the picture if this will fit a xray? (without drilling any holes) Or know of a place that sells 48p RW racing spurs that will fit. (i did ask the website and they said "they had no idea")
http://www.rchobbies.com.au/store/pr...ba57a8ae8088ca
#1164
#1165
It will fit with some sanding on parts 305577 (just the outside of the pulley and the propellor shaped spacer). You need to make them just a little bit thinner to make it work since the spur is al little thicker than the x-ray ones.
Good luck
Good luck
#1166
#1167
thanks everyone for your quick responses
#1168
Does Xray supply carbide diff trust bearings and diff balls?
Was wondering if they come in the kit or not. Thanks
#1169
#1170
Woohoo! We got a permanent carpet track in Southern California! This is OCRC Raceway in Huntington Beach, Ca. The car in this video is the T2 009 U.S. im reviewing for RCCA Magazine and you'll see the full review in a future issue. I cant wait for this years IIC in Vegas!
+ YouTube Video | |
