The future of 1/12 scale
#916
This doesn't apply in our case. The 2s batteries used in 1/12 scale are the same size and weight as 1s cells, so the energy storage is the same. If the motor wind is changed to maintain the same power level (i.e. 1s/10.5 versus 2s/21.5) then the battery will see the same C-rate load.
The only thing that the higher voltage buys for performance is that lighter gauge wires may be used. For a 1/12 scale car, that's a good thing!
#917
17.5 is the most popular motor size in the USA
TC or 12th
We could run any size, 13.5, 10.5 mod etc
Most choose 17.5
Not sure what that says about this market, but that's the facts
The majority of racers I talk to about 12th, don't like the foam tires, and, or think it looks too fast, or too hard to work on
TC or 12th
Most choose 17.5
#920
I'd love to run 1/12....sadly everyone here is into "spec" gt2 sedan/don't want to be bothered with foam tires.
I really caught the bug after racing my f1 and trying out 1/12 on vrc pro. The cornering speeds are just so addictive!!!
Also if there was a rubber tire for 1/12 (pains me to say that) it might catch on here.
#921
True, in Japan there are 1/12 rubber tires, they look great, but run painfully slow
12th scale is about agility, simplicity
imho
Rubber tires need 4W IS to work proper
#922
Agree that 1/12 is about agility, however rubber tire 21.5 2s might be better for beginners to control the speed. Personally I like foams but to get more people into it rubber might be the answer at my club anyways
#926
FYI, some rules of thumb are:
Power increases as the square of voltage. (Doubling the voltage gives four times the power, all else being equal.)
Power increases as the inverse square of motor turns. (Halving the number of turns gives four times the power, all else being equal.)
#928
If I'm not mistaken, there are certain class in Japan that runs 1/12 with 2s - 21.5T
If they could tame and control the speed of 1/12 with 2s Lipo, then no wonder if the world champs have been dominated by them.
At least they should've enjoyed the benefit of handling faster speed and agility of a mod 1/12 with their fingers.
CMIIW
#929
Bummer, even the little motors scream.
#930
I still think this is the better way to go...but we'd need manufacturers to step up and produce more sensored 380 motors.
