Old 03-20-2010, 11:32 PM   #841
My motor was a little under geard for the straght.Esc was warm but not hot.Can undergearing cause this.
sean nolan is offline   Reply With Quote
Old 03-21-2010, 03:17 AM   #842
PaPeRo's Avatar
I've never heard of anyone burning up a motor from being undergeared.
What is your timing advance set to?
Anyway a motor can get very hot very fast if there is no load on the motor but to get zero load you'd have to remove the pinion or have really really low gearing...lol.
What battery setup are you running?
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 03-21-2010, 10:11 AM   #843
mjamesf's Avatar
Originally Posted by PaPeRo View Post
There is no way for the ESC to shut down the system due to motor overheating. If the motor overheats it will still operate until it eventually burns up and melts the plastic/rubber coating around the rotor.
There is definitely something wrong with your gearing if your motor overheats and melts.
Are you running a separate temp probe or did you use a temp gun to see how hot the motor got?
You said the esc cut-off should be 65C but i've read the manual it says 50C. I use a temp gun and everytime it shutsdown i quickly check the esc temp and it's around 55C. I played at the track under hot sunny day & i've played at backyard on a shady area it has the same esc overheating problem. My friends said it's my gearing but i've already tried different pinion gears and no effect. I'm thinking maybe because i don't have a motor fan. The motor really is very hot everytime i run, and the esc is very close to the motor. I'll try to put motor fan and change the esc layout.
"RC is Contagious"
mjamesf is offline   Reply With Quote
Old 03-21-2010, 05:41 PM   #844
PaPeRo's Avatar
The reason why you get a reading of 55C is because the fan is still running after thermal? On my ESC I removed the fan so when it thermals the temp doesn't drop so my temp readings are more accurate than with a fan. I've measured the temp on my ESC right after thermal with no fan installed and it was 150F which is 65C.
Old 03-21-2010, 06:37 PM   #845
mjamesf's Avatar
Anyway whatever the temperature reading is, it's still reaching the temp limit of the esc which causes the overheating.
"RC is Contagious"
Old 03-21-2010, 07:05 PM   #846
JKL1031's Avatar
mann it could be a defect.
here is my 9t. http://www.youtube.com/watch?v=4y38ybNzYU8
JKL1031 is offline   Reply With Quote
Old 03-24-2010, 01:40 PM   #847
JKL1031's Avatar
Im thinking about ordering a 5.5t rather than going with 3s lipos in my 9t for more speed. what do you guys think? it seems it will be a cheaper alternative.
Old 03-24-2010, 04:01 PM   #848
PaPeRo's Avatar
The 5.5T motor is notchier so off power you're going to get a cogging effect. It won't be cheaper because you're gonna have to buy a 60A ESC to work with the 5.5T motor.
Personally I'd rather keep the current motor, get a 60A ESC and get a cheap LiPo from Hobbypartz.
Old 03-24-2010, 04:17 PM   #849
JKL1031's Avatar
thanks,,i will probly reconsider after hearing that, but after buying a lipo charger and 2 lipos, it wud come out cheaper.
Old 03-25-2010, 10:21 AM   #850
knd
Hi, maybe i've used wrong the search function, but here it goes.
What's the recommended battery discharge rate to use with a Ezrun 60A ESC and a 5.5T motor? I'm asking this because bigger discharge rate = expensive batteries.
What's the recommended FDR interval for the 5.5T motor?
Is the 8.5T/9T worth it? I'm going to use it for bashing and some race with friends at RC tracks.
one of the tracks used: (
h**p://maps.google.com/maps/ms?ie=UTF8&hl=en&oe=UTF8&msa=0&msid=10607118160123 4142390.00045180512d3e2a6a368&ll=38.725055,-9.197145&spn=0.001369,0.002411&t=h&z=19
Final question...i'm going to have problems using Tamiya plugs?
Thank you all
knd is offline   Reply With Quote
Old 03-25-2010, 11:09 AM   #851
JKL1031's Avatar
Well with a 60A ESC, id say u want to find someting close or a tad over 60amps. (mah rating)/1000 *C rating.
from the few post above, its said that the low turn un sensored motors have cogging at low speed. so 5.5t would be faster, but maybe more frustrating and laggy.
as far as 8.5t and 9t, someone mentioned that the 8.5 T didnt have much more torque than the 9t. I believe the smaller 380 motor in the 9t will help with efficiency, but I may be wrong.
Im not sure how hot the tamiya plugs would become since i changed mines at the same time i went brushless, nor can i vouch for the differnce in performance. but if u can get deans, get them.
Old 03-26-2010, 01:16 AM   #852
I just bought a Turnigy 35A, either a copy or just rebranded EZRun....
$29, sooo cheap
Looks the same, i'll have to put em side by side & compare more closely.
Does smell different to my EZruns
1101 is offline   Reply With Quote
Old 03-27-2010, 02:25 PM   #853
JKL1031's Avatar
I have a feeling my motor is ruined. every few seconds i hear a "Shaack" noise like something inside is catching when im running. like the motor is yelling "ggaaccckk" or something.
any ideas?
Old 03-27-2010, 02:52 PM   #854
32819toon's Avatar
Default "interference"
Hi,
I recently had a problem were the car would suddenly stop as if a failsafe was kicking in, and then starting and running intermitently. I though the problem was my Spektrum receiver and sent it for repair. Iit was returned with a job sheet saying that there was nothing wrong with it and just needed cleaning.
Since then I've used a second receiver and the same has happened again so I've ruled the receivers out. Could this problem be caused by the Ezrun speed controller ? Has anyone heard of this before ?
Also, maybe a coincidence, but we've recently started running transponders, is this just a coincedence ? No-one else at the club has suffered this problem.
Any help is appreciated.
Regards,
32819toon
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 03-27-2010, 04:32 PM   #855
Trader Rating: 22 (100%+)
Default Battery
Thank you all
If you have the money to spend get lipo, something like 4000/5000mA with the highest "c" rating you can find . They will deliver all the punch you will ever need and also give good run time.
If you are limited by your wallet, like me (and many others) Just get whatever lipo you can afford. I have cheap Yeah Racing 3200 20c lipos. I have had them for about 18 months, never ballanced and I use them just for racing with an Assoc T4 with H/wing 60A and a novak 6.5. I get about 7-9 minutes run time and I won our clubs last open mod truck season with this set up. (mind you one of the batteries is getting a bit dull and will be replaced very soon)
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
