KO Propo VFS-2000 ESC
#721
Originally posted by tornado
Errrrrr. ....... is there a huge difference between the already excellent esc VFS2k and the new VFS 1 ?
Better run time ? .... by how much ?...........easier on the comm ?.........
they did remove 8-10 stages from the bottom end, but still provide for plenty of punch. VFS-2000 is still a great esc, the VFS-1 just improves on it by allowing for finer throttle profile adjustments. they've also added throttle response, current limiter and other features that the 2000 didnt have.
#722
Guest
Originally posted by Hebiki
hey tornado... the VFS-1 has been optimized with more drive frequencies and stages. Ko Propo has increased it from 32 stages to 64 stages. this allows for more run time for hotter mods and more fine tuning. Races in japan are 8 mins in length so the addition drive stages and higher frequencies help this.
I'm thinking of getting one actually......just needed some clarifications on its features, so on and so forth before deciding. .......oh Santa.....I've been a goody goody boy ....
#723
new vs old
Can I program vfs-1 with my old setting adapter? Would there be any advantages to the new setting adapter and is the new one compatible to vfs-2000?
#724
Re: new vs old
alien too
due to the changes in the number of drive frequencies, the VFS-1 cannot be programmed with the old adapter. also, the new handheld adapter has been reworked so it can program the ICS line of Ko products by using different data cards and vice versa.
hope that helps.
#725
Sorry for asking a question i'm sure is answered some where back along but .......
Will my pc link lead from my existing 2000j work with the vfs-1 or will that also need replacing ?? like the adpt. ???
Thanks and sorry for having to ask too .....
Happy holidays
Happy holidays
#726
Happy holidays
Happy holidays
#727
Brakes
Hi everyone,
I've just got a VFS-2000 (i know everyone is goin to the VSF-1, but I wanted to give it a go). The problem I have is that the brakes on it seem almost none-existant. I am running a 19 turn V2 with 3 diodes on it the protect the speedo, and the caps etc. The only thing seeming slowing it down is the drag from the motor. Any ideas
Cheers
Crashmaster
Cheers
Crashmaster
#728
If your radio and speedo have both been set-up together and are calibrated together per the speedo instructions i'd guess you got a blown up speedo.
Check your transmiter setting though i.e expotential throttle travel limits etc. then re set-up the speedo to the radio and test if it's still the same i recon you'll have to send it off for repair.
This as i know from first hand experience is a painless excerise and will not take long at all before it's back in your hand even if your pocket is alittle lighter for the expenience
hope this helps >?
hope this helps >?
#729
Cheers mate. Checked all through the radio etc, and it hasn't made a difference unfortunately. The forward is fine, just the brakes which are the problem. Do you have any idea what the proceedure is for returning the speedo's for repair/ the costs involved?
Cheers
Crashmaster
Cheers
Crashmaster
#730
LOL
Earlier in this thread there's a sort of account of the troubles and hassels i had trying to get KO to take resposibility for there 1 week old faulty speedo.
A load of crap really about how even though i bought it in the USA i should try and get KO UK to repair it.
KO UK were saying that they wanted paying to repair it as i bought it in the USA. no surprises there. In the end i had to get some high up guy in KO japan to sort it out for me ;+) which he did and i sent it back to KO usa who had it repaired and back with me in like 2 weeks only and all but 2days of that was it traveling there and back !!!
the proceedure depends on wether you bought it new ??
If you did, it needs to go back to the shop were you got it.
If it's going for repair (not warranty) you need the UK importer i think. I can't remember off hand who that is but i'm sure it's mention further back the thread if you want to look.
Sorry i cant be of more help !
#731
Cheers mate. I'll look into it.
#732
Ive had my VFS fried a few times, sent it to KO USA, Robert was always kindly enough to repair it for me and send it back. All iIhad to do was pay for repair cost. I think it was like $40? It was a blown FET and a power coil part.I rember. Because I was running a 7turn without any shocky diodes and using the brakes...lol Doooohhhh!!
#733
Nice. I'll have a word with Helger and see what they say.
Cheers
Crash
Cheers
Crash
#734
Just got hold of a pc interface. How do I go about programming my vfs 2000j. I have downloaded the vfs2000 manaager software off the ko website and i haven't had much success .
#735
diodes
Hi guys,
What number of diodes (not the super ones, just nomral ones) would you recomend I should run on a 19 turn stock motor?
Cheers
Crashmaster
Cheers
Crashmaster
