Old 09-26-2008, 12:56 PM   #151
JCarr's Avatar
Since I am new to big races like this I have a lot of noob questions but I will try to ask the important ones. I see the rules say the motors have to be roar legal. I have a Speed Passion 13.5 in my WGT car that is one of the ones prior to them becoming roar legal. Can I use this motor or will I have to get a new one?
Thanks for puttin up with me.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 09-26-2008, 02:07 PM   #152
~McSmooth~'s Avatar
As long as it's the SPF135 Ultra Sportsman Stock, then you're good to go.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 09-26-2008, 02:13 PM   #153
JCarr's Avatar
Thanks, I believe it is but I will double check when I get home.
Gorilla Size Racing
Old 09-26-2008, 02:26 PM   #154
chicky03's Avatar
Send a message via AIM to chicky03
Default Spec Tires for World GT
We have decided that we will have a World GT spec compound for the Northeast Grand Slam Series. BSR and Jaco have agreed to both have the Lilac compound as a spec tire. Here are the part numbers:
BSR:
Front F1033-GT Front Team Purple (Lilac Equivalent)
Rear F1034-GT Rear Team purple (Lilac Equivalent)
Jaco:
JAC2100- Front control tire (Lilac)
JAC2110- Rear control tire (Lilac)
Thanks!!
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 09-26-2008, 02:50 PM   #155
Regional Moderator
Jim Herrmann's Avatar
Paul, that is good news. Keep up the good work.
Jim
Jim Herrmann, ex-Professional (turned Life Coach)
Jim Herrmann is offline   Reply With Quote
Old 09-26-2008, 02:53 PM   #156
Regional Moderator
CarbonJoe's Avatar
Jim
Awesome, Jimmy, simply awesome.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-29-2008, 06:29 AM   #157
chicky03's Avatar
Default WORLD GT rules
Here are the most current World GT rules from Bruce Carbone. There are a few changes from Vegas. Here they are:
* Raised min roof height from 95mm up to 104mm.
* Lowered min weight by 1 ounce. 40oz to 39 oz
http://www.worldgtrc.com/WGT_2008_Rules.pdf
Old 09-29-2008, 06:38 AM   #158
1fastdude's Avatar
Trader Rating: 15 (100%+)
Hey, am I allowed to run 17.5? I can't remember the last time I made an "A"!!!!!!!!!!! I can't hardy cee any more, my heering is bad, I have bladder problems, and I drool alot.
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 09-29-2008, 07:52 AM   #159
chicky03's Avatar
Sorry Eli, you made the main last year at the carpet nats and finished second if I remember correctly. You have to run 10.5.
Paul
Old 09-29-2008, 07:54 AM   #160
1fastdude's Avatar
I did? I don't remember that!!!!!!!!!!
Old 09-29-2008, 09:18 AM   #161
JCarr's Avatar
I mailed my entry in on saturday, but after I dropped it in the the box I realized i didn't put my complete email address on there. It probably isn't that big of a deal but should I PM that to someone one here?
Gorilla Size Racing
Old 09-29-2008, 10:08 AM   #162
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
PM it to Chicky.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-29-2008, 10:52 AM   #163
chicky03's Avatar
You can PM me.
Paul
Old 09-29-2008, 11:58 AM   #164
JCarr's Avatar
Thanks guys, Chicky ygpm.
Gorilla Size Racing
Old 09-29-2008, 01:26 PM   #165
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default Update - Class Descriptions
CLASS SPECIFICATIONS
(Updated 10.06.08)
Stock 1/12
Motor: ROAR Approved 17.5 Brushless
Battery: ROAR Approved 4-Cell NiMH/NiCd 5300mah max
Tires: Foam
Body: ROAR Approved GTP/Can-Am
Minimum Weight: 865 grams
Maximum Width: 172mm
Minimum Ride Height: 3mm
Pro 1/12
Motor: ROAR Approved 10.5 Brushless
Tires: Foam
Stock Sedan
Battery: ROAR Approved 6-Cell NiMH/NiCd or ROAR Approved 7.4V LiPo
Tires: Foam
Body: ROAR Approved GBS
Minimum Weight: 1415 grams
Maximum Width: 190mm
Minimum Ride Height: 4mm
Body Height: 130 with 20mm blocks
Pro Sedan
Tires: Foam
SuperStock Sedan Rubber
Motor: ROAR Approved 13.5 Brushless
Tires: Premounts Only. Xenon 28 XENTTR0128M4, Speedmind/Sorex 28R, Jaco Green, Jaco Blue, Take Off RP30
Body: ROAR Approved Sedan
Minimum Weight: 1525 grams
Minimum Ride Height: 5mm
SuperStock Pro-10
Tires: Spec Foam, BSR Spec, Jaco Spec, and CRC Spec
Body: 200mm 2-door Sports Car. No GTP or Can-Am
Minimum Weight: 1106 grams 39 oz.
Maximum Width: 200mm
Roof Height: 104mm
Raceway Choice
Class and rules to be determined by the host track
http://www.usvintagetransam.com
** ALL OTHER ROAR RULES APPLY IN ALL CLASSES**
SERIES WEBSITE:
http://www.northeastgrandslam.com
TRACK [THE GATE] WEBSITE:
http://www.clevelandcarpetracing.com
ENTRY FORM:
http://www.rctech.net/forum/4801863-post94.html
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
NORTHEAST PRO SERIES [email protected] RCE trebor Electric Off-Road 0 02-15-2007 06:41 PM
R/C Pro Northeast Electric Series Round 2 Feb 17 - 18 rcexcitement Racing Forum 0 02-07-2007 02:47 PM
R/C Pro Northeast Electric Series Round 2 Feb 17 - 18 rcexcitement Electric Off-Road 0 02-07-2007 02:47 PM
ORRCA QLD Grand Slam, Offroad Inter club series TWISTED Australian Racing 190 10-31-2006 05:16 PM
Grand Slam Superspeedway in Ft. Smith, Ar tounzen Track Locator Forum 9 10-04-2002 08:59 AM
