Like Tree5Likes
Tamiya TB-03
Old 12-25-2009, 11:13 PM
  #1531
Trader Rating: 4 (83%+)
You have to buy 2 sets just to get 4 red springs huh?
Will HPI shocks fit? I heard they will, which ones will fit?
WHat are the shock mm?
DriftWoof is offline
Old 12-26-2009, 08:14 AM
  #1532
dodo's Avatar
yes you have to buy 2 sets, not sure if tamiya has it in separate packages just like the short version.
HPI/HB shocks should fit cos TRF drivers use it but i'm not sure on the size.
dodo is offline
Old 12-26-2009, 08:25 AM
  #1533
CSaddict's Avatar
I run the reds in the rear. I run a stiffer spring in the front. This seems to give me more rear grip.
CSaddict is offline
Old 12-26-2009, 10:24 AM
  #1534
tech5's Avatar
Default 2010 RCGT TB03
2010 TB03 RCGT CAR
tech5 is offline
Old 12-26-2009, 12:38 PM
  #1535
If anyone knows what type of HPI shock springs will fit the stock CVA shocks on the TB03 let me know. Much appreciated.
Old 12-30-2009, 10:40 PM
  #1536
SoCalGuy's Avatar
Originally Posted by SoCalGuy
Thanks Jimmy; Here ya go...
All Tamiya part numbers:
53993 Aluminum Rocker Arm Set
53999 Rocket Nut
42102 TRF Special Damper Set
54052 Aluminum Propeller Shaft
54053 Aluminum Propeller Joint
54094 Aluminum Spur Gear Mount
53500 Universal Assembly Shaft Cross Joint
54076 Wheel Axles
54077 Aluminum 44mm Swing Shafts
54054 Aluminum Motor Adapter
54150 Aluminum Motor Mount
54056 Aluminum Diff Joints
51000 Servo Saver
54095 Aluminum Racing Steering Set
54097 Carbon Steering Link
54121 Aluminum Servo Saver Horn
Futaba BLS551 Servo
Castle Creations Mamba Max Pro w/ 5700kV brushless motor
(a bit concerned the stock gearing may not be correct for above motor)
Spektrum DX3R Radio with SR3520 Receiver
Have yet to decide on a good lipo battery
I may not be able to drive worth a darn, but it will sure look cool
Thanks again!
Don
After some more research, it seem some are using the 46mm Swing Shafts rather than the 44mm I purchased. Am I OK to still go with the 44mm???
Thanks...
SoCalGuy is offline
Old 01-05-2010, 02:59 AM
  #1537
Thanks...
I'm currently using the 44 swing shafts and they are working great, maybe if you are using 3rd party hop up you need a longer swing shafts.
Ciao
Max
mtaddei is offline
Old 01-05-2010, 07:24 PM
  #1538
SoCalGuy's Avatar
Thanks Max.
Pretty much done with the build, and they seem to fit fine. Hope to finish up this weekend and give this thing a spin! With a 2 1/2 year old daughter, and a wife with an ever growing "honey do list", it's a nightmare finding the time to work on this project.
By the way Max (or anyone else), what are your overall impressions of the car? I have read every post on this forum, and it's turned into one big blur in my brain
Regards,
Don
SoCalGuy is offline
Old 01-07-2010, 08:35 AM
  #1539
SoCalGuy's Avatar
Anyone know where I can get the ball studs seen in this picture? I like the fact they can be removed with a hex wrench (rather than having to pry off the tie-rod or shock), not to mention the cool blue color .
Thanks!
SoCalGuy is offline
Old 01-07-2010, 08:58 AM
  #1540
phisher's Avatar
Trader Rating: 14 (100%+)
Anyone know where I can get a good starting setup for rubber tires on carpet? I will be running stock class on a smaller indoor carpet track. I have found little in the Evo IV thread. Any help would be great, thanks.
phisher is offline
Old 01-07-2010, 09:28 AM
  #1541
Thanks Max.
Regards,
Don
Ciao Don,
i'm also fighting with my wife, and for my luck i don't have a child yet, but i hope for a boy .
Anyhow, thaking into consideration that a resume my hobby after 6 years of stop due to job trouble, i'm very happy of the car, the model is quite easy to set up and with the right hop up also fast, when a start once more i purchased a team magic e4rs, but the feeling with the model was not good.
last sunday i was on the track and my model was faster than many xray, that here in italy is the most used model.
For Phisher,
Check previous post as Timmie published a carpet set up for me.
Ciao
Max
mtaddei is offline
Old 01-07-2010, 09:32 AM
  #1542
Don, i sent you a pm
mtaddei is offline
Old 01-07-2010, 10:33 AM
  #1543
phisher's Avatar
Originally Posted by mtaddei
For Phisher,
Ciao
Max
I'm not finding the post, you mind sending a link? Thanks
phisher is offline
Old 01-07-2010, 11:06 AM
  #1544
AWK
AWK's Avatar
Thanks!
Attachment 538778
5x5mm: http://www.tamiyausa.com/product/ite...oduct-id=53906
5x8mm: http://www.tamiyausa.com/product/ite...oduct-id=53907
AWK is offline
Old 01-07-2010, 11:13 AM
  #1545
CSaddict's Avatar
Front spool is a must on asphalt and carpet.
CSaddict is offline
