TRF414M, 404x, 414, 414X
#2911
Originally posted by Calvin Ng
so you still need to drill holes?
#2912
Originally posted by FUK_WRX
I may be able to give you the orig. center onway if i can find da damn thing
#2913
i herd the TA-04 center one-way was alot more durable...
maybe u wanna do that so u wont bust another one
#2914
Nar the standard TA04 oneway is shit, we used to do one a run when we were running them, the Alloy 414WC ones are far better, the oneway bearing seemsfar more robust, i did 20+runs on mine at the euros and i did not have any problems with it. Rick
#2915
Both use the same one way bearing and breaks. It's just a matter of being lucky or not...
#2916
is it normal for these to break so easily? what about the front oneways? are they just as fragile?
#2917
Originally posted by poop
yep i agree, and i was the unlucky one . i was using the aluminium 414wc one and it broke in just about a month of using it!
I've stripped the standard plastic pulleys... but I've never used the alloy one-way... so can't give any help there
the front one-ways seem fine... been using one for about 6 months now and its doing the business without a fuss
#2918
There is no problem with the front one way, the one way bearings are much bigger and hold half of the power.
It's not a problem with the plastic at all.
#2919
Originally posted by ShadowAu
Define what you mean by "break"?????
#2920
hey that would be cool....
down the straight the center one-way breaks and through the wrest it fixes
#2921
JohnA. Countersunking the bottom chassis at the tape slot is not a problem for me. I have the tools and I have done it before.
I'm wondering if the distance of the two holes on the XRay hold-down bars would be the same as the distance between the two slots of the bottom chassis of the 414w. Could you pleae kindly clarify this? Many thanks.
#2922
#2923
JohnA. In that case I will take your word for it and I'll go out to buy a pair of XRay battery hold-down bars and fit them to my 414w. I suppose your 'memory' of your brother's car should be pretty reliable. Thanks again anyway.
#2924
can some one supply pics of their alternative battery mounts? be it xray or otherwise, i had a quick look at mounting the xray mounts, and to me it looks like the strap holes are fractionally too far apart.
for such a great car there must be an alternative to either velcro or tape
