Tekin RS ESC sensored
Are you using rubber tires????
If so then your problem is almost certainly that your brakes are locking up and all you are doing is skidding to slow down.
Turn your brakes down using the hotwire to about 80% and you should notice an immediate difference. You brakes will be as good as any other speed controller on the market.
I know this beacause I have been through the same problems and after many e-mails to Randy trying to figure the problem I finally tried turning the brakes down and instant success.
You guys wanna see what happens when an RS is having software issues?
Thank guys.
I'm not even sure thats what happened. The lipo battery wasn't hurt in any way, and I ran it in my first and third qualifiers on Sunday. It ran for about 10-12 minutes after it finally accepted the 203 software, then suddenly stopped and started to smoke. By the time I had ran off the drivers stand there was a 3-4 inch flame on it. I have already contacted Tekin and it's on its way back with a copy of my receipt. Hopefully since nothing else was hurt in any way, this will be a warrenty issue.
Thanks a lot SUV-ETR...that's what I was needing.
there is 2 possibilities, Input wires and, receiver wires.
as capacitor remain well.
and signal wires seal is burned rather the black and red receiver wires,
and The power input pin connection Tin is all melted.
Obviously cause by input power for such high temp.
anyway tekin case and output almost fine.
So it's not caused by software.
availability????
Does anyone have any idea when these esc's are likely to be readily available again????
