Tekin RS ESC sensored
#9392
Yes, drop 4 to 8 pinions from the Vegas 1.0 setup.
No, 40 in timing boost, motor set at 0.
#9393
How holds the X12 motor it with the new software?
Dit you try it on the track?
I want one for the nationals but as it can not handle the rpm's that the Tekin will give it now, i will take a speedpassion V3.0
I wanted Tekin but it's not allowed.
Ad my club it will be Tekin 13,5T
I also really like the timing adjustment on this motor.
I was also thinking the term RPM for boost start and end may be a little better reflective as not real RPM's but as increments for on road. As it is way to difficult to calculate for an onroad track. The changes I made to rpm start and end was interesting. It seem to smooth the punch if you lowered the start rpm. This lagged the motor some and generated more heat.
#9396
Setups at 55 work great, I always suggest going "small" first than going up the higher levels....
#9397
#9398
R/C Tech Elite Member
#9400
Trader Rating: 51 (100%+)
Anyone have any 1/12th 13.5 1s 3.7v lipo setups you can pm me I race ona 100x40 track carpet. any help would be appreciated
#9401
#9403
try this
refresh your page and you see the new version.
#9404
I loaded up v203, set timing to 40, boost to 9, rpm end to 10k, start at 3k, ramp 2, delay .1, with my duo 17.5 and it sounds very strong. Granted I won't get on the track for a while, and it snowed today, but compared to the delay of boost before, I think this software will have alot more punch. I'm sure I'll end up changing those settings 10 times before I run the car just to see how it responds.
