Tekin RS ESC sensored >
Old 12-30-2009, 09:34 PM
  #9196
tallyrc's Avatar
Originally Posted by Casey Belarde
Did I miss the link some where??? has the 2.03 software update been released?
if all goes right, around newyears or so
tallyrc is offline
Old 12-30-2009, 09:36 PM
  #9197
Trader Rating: 23 (100%+)
Not until Friday. Read the last few pages and you will learn all you need about it.
SteveL is offline
Old 12-30-2009, 10:23 PM
  #9198
whynot's Avatar
Trader Rating: 18 (100%+)
I got my tekin rs and hotwire and novak booster an I must say it is kinda confusing on how to get this all set up, the right way, with the right program.Is there a a guide to get this all set up correctly?
mike
whynot is offline
Old 12-30-2009, 10:39 PM
  #9199
oze
mike
It is easy. You connect your esc as you would do, i.e. + to battery +, - to battery -, A to motor A, B to motor B, C to motor C, and the receiver connection to receiver's THR. Then you take your Novak booster, you solder the red wire to the ESC's +, the black wire to the ESC's -, and you plug the other wire (with the futaba connector) to the receiver's AUX or BAT.
Switch on procedure: 1. switch on Novak, 2. switch on ESC
Switch off procedure: 1. switch off ESC, 2. switch off Novak.
oze is offline
Old 12-31-2009, 01:28 AM
  #9200
all right! Never had a problem against other speedos ever since jumping over to tekin. With the new software, I expect to totally smoke them on the straight. The only problem is that everyone else is starting to buy tekins too. Not sure what the other companies are dilly-dallying for, but what wins on Sunday sells on Monday.
redbones is offline
Old 12-31-2009, 01:31 AM
  #9201
tc3team's Avatar
Plenty of adjustment and a constant progression in software development will always make it a popular choice!!!
My car won't ever see another ESC
tc3team is offline
Old 12-31-2009, 03:33 AM
  #9202
Originally Posted by 20 SMOKE
you are border line, but it is recommended in 4wd offroad to use the pro do to the load the drive train and tires put on the esc
okay maybe i just get the pro then.
MartinBasse is offline
Old 12-31-2009, 05:01 AM
  #9203
I have the same problem. When I got mine I was the first and only one driving with the Tekin.
Some told me GM was the way to go but I stayed with Tekin and I got faster and faster.
4 of the 7 GM drivers switched to Tekin and 0 of them complained of the power.
We have now more than 14 Tekin drivers and more coming.
GM 3 and SPX 2 so Tekin rules at my club.
Not all the drivers have a hotwire or now the right setups.
After a driver used my setup and won from the other Tekin drivers and was faster than a former GM driver, I must setup almost all the Tekin speedo's.
1 advantage, I can diside how fast they go
I will stay with Tekin, They are by far the nr 1 for me by price, quality, service and speed.
mikky32 is offline
Old 12-31-2009, 05:16 AM
  #9204
trerc's Avatar
Trader Rating: 89 (100%+)
Hey guys, so I registered on Tekins website with the link posted for the Vegas software (which I already have). My question is with the registration will the new V203 software be either sent to me (via email) or available for me to download tomorrow? Just wanna make sure I'm on the right boat here, Thanks.
trerc is offline
Old 12-31-2009, 05:47 AM
  #9205
ian plimmer's Avatar
not long now guys
hope i can get hold of ot for my meeting on the 2nd, there will be at least 5 of us running tekins that day.
i would think they will update the vegas link page with the new software
ian plimmer is offline
Old 12-31-2009, 06:23 AM
  #9206
Skiddins's Avatar
Originally Posted by Ron Goetter
Are you running it in 13.5 or 17.5?
10.5
Skiddins is offline
Old 12-31-2009, 06:40 AM
  #9207
Trader Rating: 118 (100%+)
I'm about to pull out my new Tekin 17.5 motor and give it a try... Have a Ballistic now and love it, but want to try this Tekin.
Any suggestions for a starting FDR range for the Tekin 17.5?
And the preset 12 degrees is actual 12 degrees or something like 32?
Chris Furman is offline
Old 12-31-2009, 06:43 AM
  #9208
ROBORAT's Avatar
Originally Posted by MarkBrown
I've written a document on the RS / RS Pro that contains a pretty extensive troubleshooting section. It describes how to treat this symptom among many others.
See http://rcfaq.weebly.com/tekin-rs--hotwire.html
The doc is current with the v200 vegas firmware.
hey mark, this document you wrote was awesome. thi helped me a lot when i started out with my rs pro when i got it about a month and a half ago. do you plan to update it once you get hold of the v203?
ROBORAT is offline
Old 12-31-2009, 06:45 AM
  #9209
Trader Rating: 21 (100%+)
I hope he does.
lidebt2 is offline
Old 12-31-2009, 07:05 AM
  #9210
TrevCoult's Avatar
Originally Posted by ian plimmer
not long now guys
Hopefully one way or another I'll have it with me at Tamworth Ian. There will be at least 8 people running 12th with and RS or RS Pro, probably more.
Trev
TrevCoult is offline
