Tekin RS ESC sensored
#5401
Dazza is like me, if he goes out testing you need to know the details before you assess his speed as he may very well be running poor rubbers or something else specific. I doubt a speedy will pick you up that much but it can help you alot for sure.
Good to hear that it can handle a 4.5 alright in decent temp as I am looking into a possible change in ESC due to this stupid weight crap. I have heard it mentioned before that the RX8 is better for mod but it is also big and heavy. how much does that change if you rip all that crap off the top of it and use a smaller size fan?
#5402
Mikky:
Did you set your EPA to 90% calibrated the speedo with the radio and after that set the EPA back to 100% or even higher?
No
Timing on 15. Why so low?
During the test, at 25, it show for a couple of times a "blanck" for a couple of seconds. Imagine a thermal stop, last a second or two, then I could drive again.
So I set it down, not a single exitation during the whole day. Don't forget that afternoon can be very hot in Italy on summer...
This because of the Lipo?
I've tested the system with LRP 5300-25C (3 different packs) Trak power 4900-20 and 25C, a pack of Vampire. Same story.
On a short track like this one, the "softy" was not so appreciate, on a larger track (22-23 sec/lap) is way more evident. Lap times doesn't change, you felt less push out the turns. Say you change a bit your drivng style and lap times are constant.
During 2008 I was a "blue" boy Never goes "softy".... but smoke 3 times in a season...
Did you try a higher Timing?
Not yesterday. With the Speedpassion 4.5 on larger track I was on 45, but I had 2 thermal...So I went down again at 25.
Useful to say, is that the "softy" moment is less soft with Tekin than with Speedpassion
No
I have run with my Speedpassion V1.1 and 2.0 with 4.5 and 3.5 motors on lipo and never experienced this soft feel you mention.
Only thing i can think of is that the motor is getting hot and fading .
try drop a tooth or two on the pinion and add some timing if you need a bit more speed.
alternative drop your timing with the gearing you have currently.
Also using 25c lipo batteries tends to drop of in voltage after a few minutes.
For mod you will notice a big difference with 35 or higher c rated lipo batteries.
#5403
Do you use a fan on your soldering post?
because I think that as you can keep your speedo cooler, that you will have more power.
Try it with your EPA.
From the Lipo's I thought that you used 15 timing because of the power of the lipo's.
With so much power I can;t keep my car on the track.
I want to see it how it goos.
Lipo power... honestly speaking, they never impress me that much. For a certain time in my racing career I've had access at Orion driver batteries...just before lipo went on.
EPA oversetting
at the begin of my tekin moment I was doing that, due the fact my Futaba was not always "found" properly, then I change to a new Futaba VCS Fasst.
Always found properly, therefore i never over EPA again.
#5404
Razzor
Motor is 70ish (celsius).
I can't drop any pinion, motor is already collapsed against the mount... Losi room....
About the lipo dropping...
As told last year I was blue... never had that feeling, and I was using trakpower 4900 20C and 25C.
I've some 40C on the way to me, I will tell you then...
#5405
The only mod I drove was with a 4,5 LRP X11 on 5 cell.
Never with lipo.
I drive now 10,5 Lipo and 10,5 5 cell.
This Sunday I go to race with a Tamiya sport tuned.
So for me 4T with Lipo is fast.
Never with lipo.
#5406
Mikky
Sorry, It wasn't my intention.
I mean, the old (at least the last I've used) IB4200 were much "harder" than lipos.
Those batteries were really giving you a boost!!! Lipo are "flatter" in this regards.
And, without a doubt, a 4T is definitely a fast ticket, with any kind of battery!
#5407
Well hopefully I will be able to solder them back in without too much trouble. I am using the side pods on the F104 and there was room, but did not like all the wires running up uver the upperdeck. I did not realize there are differnt trays. Maybe I should look at what I have left in the box.
#5408
before you do that, i have an RS with the posts removed. The esc has only seen 17.5 and has never seen more than 1 led temp wise. If your not over heating, you will be fine.
#5410
The RS-pro with motor mod (3.5, 4.0, 4.5) have problems temperature..... engines mod can be put and not have temperature problems, but the result will not be competitive.
Whit motors type stock Rs is the best............
#5411
How long have you lived in oz? It gets that hot everywhere in summer!
but he did bounce back in the next heat
good to see him back racing but i didn't see you last night
are you guys traveling to Bathurst for CC
AS for the rs pro v RX8 send randy a pm he has been very helpful
and im sure he would be interest in a driver of your caliber
#5413
showing some TEKIN support on the VTA car I finished today!
Hint : look in rear glass
Alex
Alex
#5414
Temp around 60-70 C
#5415
Ya a couple of days a year maybe but 35c often ( my poor irish skin )
