Tekin RS ESC sensored
#2716
Hi Randy,
Thanks for the setup and I'm from Melbourne, Australia.
Cheers,
Steve
Cheers,
Steve
Anyone looking for 189 software needs to email me for it: [email protected]
I request to know where you live/race so I can point out any team drivers in your area.
For the 17.5 TC you can try this setup:
#2717
FYI
Just FYI:
The Tekin RS is up for viewers choice on www.rctvlive.com
so if you have not done so already. VOTE!
#2718
hey Randy
#2720
#2721
I got a pm and was asked what I was using on my oval 4 cell 13.5 car setup wise on my speedo so I decided to post it here to. Sensored only...Boost all the way up and the motor timing all the way down. I run my neutral. setting at 10 . And my throttle on most aggresive . No brake at all. My oval lipo car is the same except I run neutral at 8.
THANKS TO MY SPONSORS :
TEAM TEKIN, T.M TIRES, LEADING EDGE,
TEAM SCREAM, WIZARD
TEAM SCREAM, WIZARD
#2723
If you have the 189 Randy posted a good setup just a few posts up. To run it, you will want to turn the motor timing on the can down to zero if the DUO lets you. If it doesn't, a good general rule of thumb for 189 is motor timing + boost = 30-35° and bear in mind that you'll end up with a numerically higher FDR that you normally would for a 17.5. Watch your temps first time out.
If you have version 180 (what the ESC would have come with) I'd suggest cranking the motor timing on the can all the way advanced and running "sensored only" mode. Dial in 90% advance in the ESC as well -- this only applies to hybrid mode (to the sensorless part), but it's good to have it in there for backup in case your sensor cable comes off or is damaged.
All of this assumes you have the Hotwire.
#2724
1.12TH ROLLOUT HELP FOR 6.5
Got the 10.5 rollout ,boost sussed .Just obtained a 6.5 so need help with.
1.Motor timing.
2.Boost
3.Rollout for large track
Would like to work around full boost if possible as have it set for that with the 10.5.
So looking for ideas and tips with the 6.5
1/12th BMI 12RR CAR.
1.Motor timing.
2.Boost
#2725
Mine ran GREAT like that geared around 3.85
#2727
If you have the standard 1.80 firmware in the speedo, you might try running dual moe with the timing advance at 100, current limit off, drag brake 40, brake strength 80, neutral width 10, brushless forward only, throttle profile 3, endbell bolts in the middle holes.
I like less drag brake and max brakes, but that's personal preference.
syndr0me -- obviously there are options, and I'm confident you'll be psyched either way.
#2729
In Dual mode at 100 on the Timing Advance bar you're getting 30 degrees of timing.
If you had your endbell cranked on a Tekin and sensored only and no boost you're at about 39 degrees. This would require a few pinions to be greared down to get the right gearing.
For a 6.5 you really should not be in sensored only mode AND no boost. However if you're dead set on it I'd turn the motor timing all the way down to 0. Check motor temps often to prevent overheating.
My 4wd mod offroad setup with a 6.5 for example:
