Tekin RS ESC sensored >
Old 02-16-2009, 08:30 AM
  #2506
Team Tekin
Randy_Pike's Avatar
Hey,
The preffered 17.5 setup in 1/12 and TC is 0 degrees of motor timing and Full boost which is 30 degrees.
Bob, if you run your "dual" mode timing at 100 this will render 30 degrees also in case you have a sensor cable come out again. This will almost match the timing in the above setup so you don't lose too much speed.
Randy_Pike is offline
Old 02-16-2009, 12:26 PM
  #2507
Trader Rating: 37 (100%+)
Josh Keller is offline
Old 02-16-2009, 01:05 PM
  #2508
Originally Posted by Josh Keller
Does anyone have any timing suggestions for 1S LiPo 13.5 and 17.5 oval? I read that the on-road guys were running full timing on the motor (24 degrees for Tekin) and 0 boost.
I'm just looking for a good starting point.
I was told to rollout at 4.00 for 13.5 and 4.50 for 17.5, if that helps.
135 foot run-line, flat, carpet.
Thanks,
Josh
Actually, you're going to want to start with zero motor timing and full boost. I've run full boost and more timing on the motor in single cell but it's really not recommended (I'm not really shure why it even works to be honest). For gearing, start the 13.5 where a 17.5-4 cell should be and the 17.5 will probably need the same increase in rollout that you make with the 13.5 but I haven't played with 17.5 as much.
Fred_B is offline
Old 02-16-2009, 04:03 PM
  #2509
Suspended
Questions??
Originally Posted by Randy_Pike
Hey,
Hi,
I recently bought two rs pro speedo's and wanted to know. How do I get the 189 software and do the 17.5 redline motors have adjustable timing? Also what is the best set up for 17.5 touring car?
kyosho player is offline
Old 02-16-2009, 04:42 PM
  #2510
bigkoitat's Avatar
Trader Rating: 6 (88%+)
Originally Posted by kyosho player
Hi,
I too just bought 2 RS ESC's!!! I bought 1 speedo by itself and the other esc and 17.5 combo. the 17.5 does have the ajustable timing on it and it doe make a big difference.
bigkoitat is offline
Old 02-16-2009, 05:23 PM
  #2511
bigkoitat's Avatar
kyosho player -
for the 17.5 I have been using the Novak setup which is 3.5-FDR, I couldnt get the right gearing in time for this past weekend and was using 4.0 with the timing advanced. the car was very smooth, I started with the mild profile and proceeded to the aggressive profile. I'm really happy with the RS ESC
Old 02-16-2009, 06:17 PM
  #2512
Team Tekin
Randy_Pike's Avatar
Right now the team is really liking the 0 motor timing full boost timing setup using 189.
Anyone seeking 189 need only e mail me for it letting me know were you race/live so I can point out any team guys in your area:
[email protected]
Old 02-16-2009, 08:14 PM
  #2513
Suspended
Thumbs up
Originally Posted by bigkoitat
kyosho player -
thank you for the advise.
Old 02-17-2009, 09:05 AM
  #2514
mac853's Avatar
Hi, could anyone tell me if i wonder using low KVs sensorless motor from any brand, then which 1 esc of Tekin could make better performance: R1 Pro or RS Pro?
Best regards
mac853 is offline
Old 02-17-2009, 10:25 AM
  #2515
Team Tekin
Randy_Pike's Avatar
Mac,
If you're going to run sensorless motors the R1 Pro and RS Pro will be virtually the same. I always recomend using the right esc for the application and since you're going to go sensorless get ther R1 Pro.
Old 02-17-2009, 10:38 AM
  #2516
mac853's Avatar
Mac,
Yes, in the case this is the same as i guessed.
Thanks for your confirm.
mac853 is offline
Old 02-17-2009, 10:39 AM
  #2517
Midnight's Avatar
Trader Rating: 87 (100%+)
Just an idea, but if I was going out and buying a brand new esc, I would spend the extra 20 or 30 and get the RS, but my wife also has me on a tight rope, so I always look at resale. If you look at the for sale forun on here, anything tekin goes in a matter of minutes. Like I said this is just my opinion.
Midnight is offline
Old 02-17-2009, 11:20 AM
  #2518
YmeBP's Avatar
Trader Rating: 32 (100%+)
[email protected]
Randy I've got a couple folks here that run the tekin redline motor and were wondering how do i tell where the timing is? I saw the degree marks on the sticker but what is the key on the endbell to line up w/ the marks on the sticker?
Lastly what does the motor come from the factory with timing wise?
YmeBP is offline
Old 02-17-2009, 11:43 AM
  #2519
HarryN's Avatar
They come 12 degrees advanced, right? My Redline 13.5 was advanced by 12 degrees when I yanked it out of its box.
HarryN is offline
Old 02-17-2009, 12:15 PM
  #2520
Hi guys,
Are there anybody who has experience with the speedo combined with a Corally BL motor?
Are they works perfectly together?
Thank You
bviktor is offline
