Tekin RS ESC sensored
Thanks Guys much appricated I'll setup the 12th this week and see how it goes.
That's the same thing I'm running now and haven't had a problem you should be ok. Dual mode works well to give it a little m9re oommpphh.
is there a way to reverse motor rotation?i have changed trannies in my sprinter now the motor is on the other side when i reverse and recalibrate my throttle setting it still runs in reverse?
just plug in the hotwire and go to setup click reverse
For anyone interested, heres the setup I settled on after a test day at the track with one of my other stock racing mates:
RS/Redline
FDR: 5.33
Start rpm: 4900
End rpm: 13900
Boost: 40
Turbo: 20 (max)
Motor: 0
Turbo delay: 0.3
Turbo ramp: 2.0
Motor temp @ 5 mins: 81*c
This felt great. We used eachother as benchmarks, my car was slower to begin with so we worked on that, then when it was faster we worked on his.
I still want to work on the end rpm, for one to get the heat down a little, and secondly the turbo is kicking in at a short straight a few meters before I break for a hairpin, but I don't want to change the turbo delay because I dont think it will then be fast enough for the main straight. I just have to experiment with it
Thanks again.
RS/Redline
FDR: 5.33
Start rpm: 4900
End rpm: 13900
Boost: 40
Turbo: 20 (max)
Motor: 0
Turbo delay: 0.3
Turbo ramp: 2.0
Thanks again.
What motor did you you use??
RS/Redline
FDR: 5.33
Start rpm: 4900
End rpm: 13900
Boost: 40
Turbo: 20 (max)
Motor: 0
Turbo delay: 0.3
Turbo ramp: 2.0
Thanks again.
RS/Redline
FDR: 5.33
Start rpm: 4900
End rpm: 13900
Boost: 40
Turbo: 20 (max)
Motor: 0
Turbo delay: 0.3
Turbo ramp: 2.0
Thanks again.
any new update software will coming soon ?
need advice, i'm planning to race on mod touring car(rubber) with rs pro and redline 5.5t on asphalt nitro track with 80 meters main straight ,med grip. The question is can the rs pro handle the redline 5.5t in sensored mode boost-turbo. need a baseline setup because since this is the first time to run mod motor on my rs pro, anyway with lrp x12 10.5t is fine for me, winning the 2011 season in our local track, setting the new track record for the 10.5 rubber category and equalling lap times of the nitros. Thanks.
for mod i find that-esc/gearing/tires is everything or the car is undrivable or corner overshoots
150ft backstraight-medium/low smooth cleaned parking lot asphalt
clocked at 52mph on the straight-mi4cx stock,
with help from others
45, 10 (12 blows the tires off the rim!), delay.32, ramp 2, drag/brake 25/81, throttle prof 1, FDR 12.75, rpm 30k/5k, 10 intiail brake/throttle/neutral width, current lim off
easy to drive in the infield and rockets in the backstraight
Anyways, if you are going to run mod full time, I highly suggest that you switch to an Speedpassion/Hobbywing speedo, or even an LRP. The "feel" and power delivery for mod is a lot better. The Tekin is an on/off switch in comparison.
Definitely disagree with that. If you don't run boost/turbo in mod, at least in my region, you will be left in the dust (even with a 4.5/5.5).
But it is nice to mention other makes of speed controllers on Tekin's thread.
Top speed at the end of our strait 110kph.
12 degree motor timing on a Tekin Redline 4.5 or 5.5
FDR approx 10.00
Boost 45
Turbo 15
Turbo delay 0.2
Turbo ramp 1
Start rpm 6000 approx
end rpm 32500 approx
Throttle profile 1
Brake min 8
Throttle min 8
Everything else fairly std of the top of my head.
Oh, run a fan on the motor if possible, although I have been coming of the track at about 75 degrees C.
