Tekin RS ESC sensored >
Old 11-28-2010, 12:48 PM
  #18511
Team Tekin
Randy_Pike's Avatar
Originally Posted by draggin87
Tekin 13.5 Geared 86/17 48p
Timing Profile c2
Throttle Profile 5
Endbell Timing 12
Boost 45
Start 5443
End 20016
Turbo 20
Delay .10
Ramp 3.0
I hope this helps, also this is in s E4RS
You are WAY overtimed. You have nearly 77 degrees of timing! That will generate a ton of heat and a HUGE power bog.
Drop your turbo to 12, drop your motor timing to 0 and drop your turbo ramp to 2.0
Go drive the car.
Randy_Pike is offline
Old 11-28-2010, 01:29 PM
  #18512
Go drive the car.
I am racing 17.5T, not 13.5T, but I got around 75 degrees of timing in my setup using a Speed Passion V3 (10 endbell, 50 boost, 15 turbo, 5k start, 15k end, Turbo ramp 3) and got low temps (50c after 6 min) geared at 5.7. I have experienced great temps and no power bog.
Nilks is offline
Old 11-28-2010, 01:38 PM
  #18513
darrenoakley's Avatar
Wow you must be racing in a fridge or something. Setting like that would kill my duo 2 17.5 in 5 mins.
darrenoakley is offline
Old 11-28-2010, 01:43 PM
  #18514
I have slowly added more timing and kept a close eye to the temps. With these settings I am reaching 50c / 120F after 6 min. This is indoor carpet racing, with an air temp at 18c / 64F.
Nilks is offline
Old 11-28-2010, 02:08 PM
  #18515
Having low temps doesn't mean the motor is working well though. With all of the timing business, you are looking for a balance between speed and acceleration. I'd suggest you may have speed, but could get a lot more acceleration by dropping the guts out of the timing.
There is a reason the pro's don't run massive timing.....
JR007 is offline
Old 11-28-2010, 02:58 PM
  #18516
I'm not losing anything in acceleration compared to the other guys. I did have to much acceleration / power with an FDR at 5.95 causing my tires to spin, so I dropped my FDR to 5.7.
Nilks is offline
Old 11-28-2010, 03:58 PM
  #18517
Trader Rating: 19 (100%+)
Hi guys, what is the lowest turn motor I can run in touring car with the tekin rs. Not rs pro
COLD AS ICE is offline
Old 11-28-2010, 04:08 PM
  #18518
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
7.5, 6.5 is pushing it
20 SMOKE is offline
Old 11-28-2010, 04:43 PM
  #18519
Buckaroo's Avatar
Originally Posted by Xpress
What is the uf rating for the TT3520 cap?
TT3520 Power Cap 16V 330uF RS / R1 / Fx series (2)
Buckaroo is offline
Old 11-28-2010, 05:25 PM
  #18520
ira
ira's Avatar
Trader Rating: 18 (100%+)
5 turn max, per. Tekins web site
ira is offline
Old 11-28-2010, 05:45 PM
  #18521
BCbud's Avatar
Trader Rating: 37 (100%+)
For 2wd, 4wd the limmit is higher like 20 SMOKE said.
BCbud is offline
Old 11-28-2010, 05:57 PM
  #18522
ira
ira's Avatar
Is that on Tekins web site?
ira is offline
Old 11-28-2010, 06:02 PM
  #18523
ira
ira's Avatar
From Tekins web site.
Controls: Forward/Brake/Reverse
ON Resistance: 0.0001 Ohms brushed fwd mode, 0.0003 Ohms brushless mode, 0.0003 Ohms brushed fwd/rev mode
Input Voltage: 4-9 Cells, 3S Lipo
BEC: 6.0V/3.0A
Motor Limit Brushless Mode: 5 Turn, 36mm can
Motor Limit Brushed Fwd Only Mode: None
Motor Limit Brushed Fwd/Rev Mode: 12 Turn
Throttle Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.3 x 1.00" x .45" (33 x 25.4 x 11.5mm)
Weight: 2.0oz with included 12G wiring
ira is offline
Old 11-28-2010, 06:03 PM
  #18524
ira
ira's Avatar
????? Where did you see this?
ira is offline
Old 11-28-2010, 06:12 PM
  #18525
BCbud's Avatar
It has been talked about several times in these forums by teem drivers.
BCbud is offline
