Tekin RS ESC sensored
i think you should be in profile 1 that way there you get the flashing light for the stock class
Let me register to read it lol
Hit F5 and refresh the page. You also may need to restart IE if you just enabled cookies.
Here is doc that the team was given:
Tekin Vegas 208 Software
for RS, RS PRO and RX8 controllers
The Vegas 208 software contains several major advances towards Tekin’s never-ending pursuit of perfection. As well as increases in performance and lower temperatures, V208 includes a ‘spec’ mode required at some races and some new features to make it all easier to use. So this time its Smarter, Cooler, Faster…
RS Spec Mode
The spec mode provides no Timing Advance or Boost in the controller. The center LED flashes when in neutral to make it easy to verify the unit is in spec mode.
RS Brakes
A major improvement is stronger braking at high speeds. Braking power is increased and is more linear throughout the RPM range.
RS and RX8 Power Delivery
To fine-tune the power delivery we have improved the Current Limiter. Most drivers have reported they can limit the current down to 80% before they even notice it. This can lower motor temps without sacrificing any power or feel. Many drivers have found it beneficial to use even use lower settings in low traction—they find their car handles a lot better without the sudden jolt of torque that can be produced by brushless motors.
Results
Team driver reports have demonstrated that the smoother power delivery and improved brakes, combined with intelligent current limiting, is producing faster lap times and lower temperatures.
Making it easier…. RS and RX8 On-Board Timing Profiles
Who needs a separate programming box when all the features are available on the ESC at the touch of a button? While the HotWire is needed for fine-tuning and software updates, we realize not everyone wants to carry a computer to the track. To make it easier, 208 has new “Timing Profiles” which are taking the place of “Throttle Profiles” on the RS’s onboard interface. Throttle Profile settings are still available using the HotWire. Throttle curve adjustments can also be made on almost all good radios.
The user can now select from 5 preset Timing Profiles on the RS and RS PRO without a HotWire
RS and RS PRO
TP1 – Spec Mode 0deg Boost (LED flashes when in neutral so Tech can easily verify mode)
TP2 – 15deg Boost, 5442 RPM to 20,000 RPM
TP3 – 25deg Boost, “ “
TP4 – 35deg Boost, “ “
TP5 – 45deg Boost, “ “
C1 – Custom settings using Hotwire
C2 – Custom settings using Hotwire
Custom 1 and Custom 2 (C1 and C2) are user-savable Timing Profiles created in the HotWire and are selected via the RS’s onboard interface. This will allow the user to run the same ESC in a “spec” class and have his or her own personal settings stored in C1 or C2 for the non-spec class at the same event/race.
RS, RSpro and RX8 Dual Mode Boost
Also new in 208 is Dual Mode Boost. This feature is most useful when used in the RS PRO with modified motors, or in the RX8 with all T8 motors. Dual Mode Boost lets users set the RPM range where Timing Advance is added, just like we already do with Boost in sensored-only mode. This is the best of both worlds for low turn motors, allowing low gearing/low timing for more torque out of the corners and higher timing for higher top speed/RPM on the straights. This is especially helpful on tracks with tight infields and a long straight.
RS and RSpro Dual Mode Boost Settings
The user can set Dual Mode Boost in the RS using the HotWire and the Custom Timing Profiles. The Start RPM should be in the upper ranges of 10,000 with an End RPM of 25,000+. The maximum timing in Dual Mode is 30deg. The setting range is 0% to 100% (0deg to 30deg) with the most common settings being 50% to 100% (15deg to 30deg).
Team drivers have noted that often they can go up one whole motor wind with the increased power band. For example if you run 4WD Off-road Mod with a 6.5T, in Dual Mode you can now run a 7.5T and get the same if not more useable power and top speed, all with lower motor temps.
RX8 Dual Mode Boost Settings
Tekin T8 motors are 4-pole, 12-slot motors with very low turns that need very little timing at higher RPM. The maximum timing in Dual Mode is 30deg, displayed in the HotWire as Timing Advance, with a range of 0% to 100%. The T8 motors are only able to efficiently use about 30% to 50% Timing Advance (10 to 15deg). Settings higher than 50% on Timing Advance is appropriate for standard 1/10 scale motors, for Tekin’s SC4x SCT motors, and for the long-can motors that some sell as 1/8 scale motors.
While Timing Advance in a 1/10 scale motor can more than double the kV of a motor, the T8 motors only increase kV around 10%, after which the extra energy is wasted in the form of heat. Run times decrease when too much timing is applied.
The user can select from 5 preset Timing Profiles on the RS, RSpro and RX8 without a HotWire:
TP1 – 0deg Dual Mode Boost
TP2 – 20deg Dual Mode Boost,
TP3 – 40deg Dual Mode Boost,
TP4 – 60deg Dual Mode Boost,
TP5 – 80deg Dual Mode Boost,
Custom 1 and Custom 2 (C1 and C2) are user-savable Timing Profiles created in the HotWire and selected via the RX8’s on-board interface. This will allow the user to have specific Timing Advance values or different RPM ranges, that are then available on the unit with just a few button pushes.
RS Spec Mode
RS Brakes
Results
RS and RS PRO
208
Firstly thanks
One question (maybe syupid)
In 203 in sensored only mode there was no timing advance only timing boost and turbo boost
But in 208 it shows timing advance in sensored only mode
Where should this be set if we want to start from the same setup as before
Firstly thanks
Yes in 203 it was hidden but still active should the sensor harness come unplugged.
Yes Pete those should be "percentage". I'll get it corrected.
Rp
Rp
Thanks krio will do that
So its just incase you lose your sensor cable or sensor is faulty
So just to clarify if I use the C1 option & still have all my Turbo & Timing setting in 0 for Spec settings the red light will not blink? So I can only get to Spec class setting by setting my ESC without using my Hotwire.
Thx!
John
Thx!
John
to go to the stock spec profile use the pit tunning(mode button) and set it to 1 in the throttle profile,that will be the spec profile.you can use the HW as well
subscribing to thread...
Looks like some more great changes as usual from a quality company like Tekin! Great job guys! I'm looking forward to trying it out.
still cant download it !!!!!
even on firefox !!!
HELP PLEASE
anyone wanna help a computor idiot ???
even on firefox !!!
HELP PLEASE
