New TEAM WAVE racing brushless system
#646
I'm a little po'ed - so I'll try and moderate my post. Please read and tell me I'm doing something wrong.
A respected racer and friend sells me a RB-50. He retires from racing (which is why he is selling the speedo).
I install it in my 2WD buggy along with LIPO, R153F Receiver, 3PM radio. Can't get it to work......lose my race fees and bother my other friends trying to get this thing to go.
Next race out - I try again with 5 other R153F's and a R133F. No go. Friend of mine lends me a 3PK with a spectrum receiver. Magic - works fine.
Go home check my TX/RX's and all seem fine.
I figure my TX is bad - buy a new 3pm and receiver - remove the shrink wrap - slap it together with the RB-50 - no go.
Thats it - I contact my friend - friction starts. We kiss and make up after a heated argument. I toss the RB-50 aside for a few months because I figure its done. So be it.
Today - on the bench, I start trying all kinds of combinations 3pm (2 tx's), R153F (X4), R133F (x1). No go.
For a farce, I take out a HPI TF-3 and cheapy receiver I have lying around. Zip Zap - programs and all is fine.
WTF is that????
Futaba R153F and R133F are not "oddball" receivers. Where is the warning on Team Wave's site saying their products won't work with extremly popular receivers? I cannot beleive this is news to the Team Wave people? Within this thread there is information about problems (my bad for not reading this thread earlier).
Very disappointed and stuck with a ESC that won't work with a Futaba 3PM and 153/133F's.
Unbeleivable.
Am I out to lunch being po'ed here?
WTF is that????
Unbeleivable.
#647
I figure my TX is bad - my a new 3pm and receiver - remove the shrink wrap - slap it together with the RB-50 - no go.
WTF is that????
Unbeleivable.
WTF is that????
Unbeleivable.
Im using a 3pm as well, and the receivers are r603ff or something along that line
#648
Just to check I have Team Wave motor ESC sensor harness cable. Was thinking if it's compatible with LRP TC Spec & motor. The connectors head are same.
#649
These are crystal receivers. I think you are referring to 2.4 receivers?
You know - I received a PM from a Team Wave representative within MINUTES with a solution.
I was po'ed for sure - but this kind of service is something I will not forget when I purchase my next new speedo.
Big Props to TeamWave stepping in with custumer service.
#650
Hi CaliberX
I had the same problem, the speedo does not work in PCM mode. I solved it by using an old novak receiver and running it in ppm mode. You'll see a few pages back I asked about this and never received a reply.
#651
Question:
Im thinking about getting the RB-S for 17.5 or 13.5 1S lipo..
Are there any difference power advantage between RB50 and RB-S for stock motor?
#652
Anybody her using this esc with M11X radio with FHSS3 type receivers? I m just asking coz I m interested to get one either the RB50 or RB-S.
#653
Hi All,
If tunning STOCK motors (8.5T - 21.5T), speed/power is as follow:
RB-S > RB50 > RB30
if running modify, RB50 is the only choice. If you are not racing or just playing drift, rock crawler, RB30 is the good choice.
The fastest way to get customer support is to send email to us directly ([email protected])
RB-S > RB50 > RB30
#654
For Radio system support, Futaba R153/R133 receiver use 2.5V signal level which is too low for RB series speed controller. All 2.4G system use 5V system already and no problem for RB series controller.
For PCM system, it will work with PCM1024 and PCM synthesizer.
If user found problem with their receiver, please send us an email, we can ship you an extension cable which can boost the 2.5V signal to 5V.
#655
Franko, get the RB-S....I will have mine soon. Should be good for 1 S 13.5. I am going to run it in a world GT car, I will let you know how it works out.
#656
Wow!!! that was a quick response brom TW...thank you...I m planning to use this esc for Mini 4wd class , will probably run 10T or 11.5T.
#657
Hi All,
Teamwave responded immediately and quickly - good on them for that.
#659
i just installed my RB-S onto my car and ran the car off the ground... with 2x turbo, i was like shocked by the power!!!... when turbo kicked in, it was like i had a mod motor in my car... WTF were the exact words that came out of my mouth at that instance...
but i have some feedback which i hope Team Wave can take in good attitude so that their products can continue to improve...
they are:
1. ESC fan is a direct connection to battery... so the fan will turn on the moment you plug in your batts even with the esc off... might consider making it turn on only when the esc is switched on....
2. My esc does not switch off... it has a quirk whereby it sometimes turn on even after i turned my esc switch off... only when i unplug does it stay off... maybe make the switch a hard switch instead of a logical one? a esc switching on by itself is kinda freaky...
3. the esc fan is freaking loud... a small complaint that i can still live with...
they are:
#660
