Advices on tb01
#46
hi, thanks to all of u that so kind for all the recommendations... really glad that still spending time to teach a newbie on rc... haha...
anyway, i just got a cheap ESC- sanwa, it only cost me $65... it supports till 12T motor... now may thinking to change a motor next month, any recommendation? 1 of the thread is talking bout 23T motor, is 23T motor good?? is the 23T a stock motor or mod motor? whats the diff??
any1 know that any hobby shop in singapore hav more accessories for tb01? like those carbon frame set??
#47
Originally posted by fabolousRC
I would like to amend this comment. Tamiya does make 27T 0.4 AV pinion for the TA04 cars (or any other cars that uses 0.6AV pinion gears). Tower hobbies have them:
Tamiya 0.6 Aluminum Pinion Gear 27T/TA04
But the max a stock TB01's plastic motor mount can take is 25t AV. I don't know if the alloy motor mount (with slots instead of A/B/C/D preset motor positions) can take any bigger pinions.
So the 27t is only for TA04. TA04 kits come std with 25t, and there's room for a couple more pinion teeth before you need to change the 87t AV spur (which is the only AV one they make) for something else. Third-party companies have been making AV pinions in 26 and bigger for a long time now.
#49
whats the diff between Type T and Type R? R these consider a stock motor?
#50
Type T and R are considered "Stock" in Singapore.
#53
Also, Type T has laydown brushes while Type R has standard brushes. I suggest getting a Type S or Type RR because these two are rebuildable while the Type T & R have sealed endbells.
#54
Originally posted by sty
By the way where do you use to play? I usually play with my friends in punggol multi storey carpark on friday nites.
#55
The diff between T n R is T stand for Torque while R stand for race. R will have 28000 rpm while T 27000 rpm. both motors are already quite fast for me. I also thought of using 11 turns but than i have to upgrade alot of things which will make it not worthwhile anymore.
should i get a lower turn motor, since my ESC can support as low as 12T motor...??
#56
BlixeX, if you are just starting out, stick with a stock motor. A mod motor requires more maintenance and you may not be able to control the car anyway.
#58
Originally posted by WC
Do you use TB01's chassis cover (the 1 with the 2 drivers)??
If you use cover, be very careful about ESC and motor overheating. The cover prevents airflow to the inside, so everything just cooks.
It is best to run without the cover.
#59
#60
NEED HELP
Hi all shifu out there,
I will be buying my next electric car next week. Thinking of buying a tb01 but now also feel like buying a ta04. Please advice which is a better car to buy. Now i have 2 TL01, one for off road and the other for on road. this next car will be for on road, Budget will be around 200-300(just car). Also all kind souls out there please kindly also tell me the average price for these 2 models, if inconvenient to disclose price here can pm me. I promise i will not disclose it to anypne. Thanks in advance.
