making lower chassis >
Old 07-16-2003, 09:55 PM
  #46
davioh's Avatar
if by woven you guys mean layered yea it is....it's more dense than the tamiya one but unlike the tamiya one, the first layer isn't fiberglass
davioh is offline
Old 07-16-2003, 09:57 PM
  #47
davioh's Avatar
Originally posted by CustomfibreR/C
I'm Just going by what I see in the Pics. It really looks like fibreglass with Black Glass cloth used on the top and bottom. The local fibreglass supplier sells the same stuff and it is cheap.
$230HK Dollars for enough genuine 3mm Carbon Fibre Sheet to do 3 chassis is too cheap to be correct.
My money is on it being Fibreglass...
it is CF, trust me. the "genuine" ones, like the original ones are sheeted with fiberglass
davioh is offline
Old 07-16-2003, 10:03 PM
  #48
I was trying to be tactful but Trust me I know cause I make Genuine Carbon Fibre Sheet..
No fibreglass cloth is used in Quality Carbon Fibre Sheet. I have worked with Modern Tamiya CF Chassis like that used in the EvoIII, 414 etc and it is all Carbon Fibre Cloth. There is no Fibreglass used for fill. What you have bought is Fibreglass with a woven cloth used top and bottom..Hence the cheap price
CustomfibreR/C is offline
Old 07-16-2003, 10:12 PM
  #49
Brian McGreevy's Avatar
Usually carbon fiber looks "woven" and has a pattern to it. Yours does not and actually does look like fiberglass. Sure you didn't get ripped off?
Brian McGreevy is offline
Old 07-17-2003, 03:22 AM
  #50
GTMilenko's Avatar
would 3mm fibreglass have more flex than 2mm carbon fibre?
GTMilenko is offline
Old 07-17-2003, 05:03 AM
  #51
Looks like a G10 fibreglass to me
no carbon content
I have that kind of chassis for my old Kyosho Lazer ZX
Mingfinity is offline
Old 07-17-2003, 05:29 AM
  #52
dtm
dtm's Avatar
Yes it does look like fibreglass to me...the same stuff that Tamiya used to use for the TA03/04 pro. Easiest way to know I guess would be the dust that came off when you cut it....if everything turned "black" including your fingers....you have carbon!
dtm is offline
Old 07-17-2003, 07:02 AM
  #53
davioh's Avatar
um..i dont think it was all black...aiya! o well...i guess this will work fine
davioh is offline
Old 07-17-2003, 07:24 AM
  #54
of coz it works
Just a little bit HEAVY and a little bit 'soft'
Old 07-17-2003, 07:57 AM
  #55
davioh's Avatar
o well doesn't matter too much to me. but glassfiber is pretty hard to cut as well
davioh is offline
Old 07-17-2003, 02:37 PM
  #56
Hey,
Regardless of the fact that it is Fibreglass not CF you still did a good Job from what I can see.... I am sure it will work a treat.
