SMC 28C 4000/5000 Hardcase Lipo part 2 >
Old 08-19-2008, 08:30 PM
  #1066
Jake S's Avatar
Trader Rating: 67 (93%+)
is it illegal to attach a small piece of lead tape or something to simulate bumps to hold the cells into a car/buggy better?
what would be suggested?
Jake S is offline
Old 08-19-2008, 08:35 PM
  #1067
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
sticker bumps
Cameron Kellogg is offline
Old 08-19-2008, 08:36 PM
  #1068
Jake S's Avatar
Originally Posted by Cameron Kellogg
sticker bumps
what do you mean? lol
Jake S is offline
Old 08-19-2008, 08:51 PM
  #1069
syndr0me's Avatar
Trader Rating: 32 (100%+)
I Shoe Goo the weights from Nexus to the bottom of my packs, and it does a very good job of locking them into the slots.
syndr0me is offline
Old 08-19-2008, 09:04 PM
  #1070
Jake S's Avatar
any links to these? the saddle pack im getting should be heavy enough with only minor setup changes, so anything around the 2oz range should work perfect with the "regular" setup.
heck maifield even ran his b44 with the same setup without any weight added with what was prob the reedy saddle (Weight: 282g - about 4 oz lighter then a nimh 6-cell pack)
Jake S is offline
Old 08-19-2008, 09:14 PM
  #1071
lbckevin's Avatar
Trader Rating: 107 (99%+)
Reedy saddle pack is not Roar approved, he could not of run it at the Roar Nats
Here is the link to Nexus:
http://www.nexusracing.com/index.php?cPath=147_319
lbckevin is offline
Old 08-19-2008, 09:48 PM
  #1072
Jake S's Avatar
Originally Posted by lbckevin
Reedy saddle pack is not Roar approved, he could not of run it.
from the jconcepts clash sheet "Lipo batteries allowed – hard shell cases recommended" so yes he could have since roar rules where just "observed"
thank you so much, too bad the 6 pc is outta stock, i think i might actually have some of them layin around from something else.
Jake S is offline
Old 08-20-2008, 12:28 AM
  #1073
The JST-XH adapter is like $7 or something. I'd like to find one that just goes straight to a 2S plug instead of using the board, since I don't plan on using more than 2 cells anytime soon.
Did you ever find a cable that would go straight into the Hyperion from the SMC?
Or is this the only option to connect the SMC's to the Hyperion? I will be using the 3200 & 5000 lipos. Thanks.
http://www.allerc.com/product_info.p...oducts_id=3159
LAGuy is offline
Old 08-20-2008, 09:21 AM
  #1074
Jake S's Avatar
i remebered i had a lipo weight played from johnny (OCD) its like the perfect width to fill the b44 cutouts for the cells (with the tray removed) just gotta get it cut into 6 pieces that are the right length, and the height of 2.5mm is perfect; since the B44 is built on a 2.5mm woven carbon fiber main chassis.
just gotta talk to a buddy and make sure he has the equipment to make a straight cut in 304 steel
Jake S is offline
Old 08-20-2008, 11:09 AM
  #1075
Jake S's Avatar
or to add only 1.4 oz instead of 4 oz i got the nexus pieces already (when i bought my older lipos they came with it) to "key" the packs in
Jake S is offline
Old 08-20-2008, 10:41 PM
  #1076
Company Representative
Danny/SMC's Avatar
Here is a picture of the colored top wire case. The red that was choosen is a bit dull and when we have a new run of case done we will go with a brighter red that will seperate itself better from the black. As usual I'm sure some will like the colors and others will not.
Attached Thumbnails SMC 28C 4000/5000 Hardcase Lipo part 2-topcoloredcase.jpg
Danny/SMC is offline
Old 08-20-2008, 10:51 PM
  #1077
STLNLST's Avatar
Danny,
Until the color is correct I don't feel that I will ever be able to TQ with this pack...... Kp up the good work!
STLNLST is offline
Old 08-20-2008, 10:54 PM
  #1078
Super Moderator
Grizzbob's Avatar
Originally Posted by STLNLST
Danny,
Ehhh, I wouldn't worry about it, the cars using it will be going so fast no one'll be able to see it clearly anyway....
Grizzbob is offline
Old 08-21-2008, 07:38 AM
  #1079
Trader Rating: 16 (100%+)
Nothing yet; but, Hyperion also needs to provide longer leads so we can get the pack(s) correctly into a Lipo Bag while charging.
Still Bill is offline
Old 08-21-2008, 10:11 AM
  #1080
R/C Tech Elite Member
Buckyaga's Avatar
will there be an option for connectors built in the saddle packs(like some of the other lipo packs) or will there just be leads coming out of the cases?
If its leads only, are they user replaceable?
Buckyaga is offline
