BMI DB10R!!!
#526
Actually it is a good idea if you do. Under impacts the king pin can get pushed up through the steering knuckle and bind causing a lot of preload on one side of the front suspension.
#527
Ran mine for the first time yesterday and was very impressed
Found I was running out of rear grip towards the end of a run so need to work on generating a bit more traction but for a fist time out no issues that a bit more track time won't sort.
Jason
Jason
#528
Use a good 1/8" reamer (Niftech make a superb straight-cut one that does the job) after the axles have been screwed in, and do it by hand so as not to remove excess material. The axle block should slide up and down on the kingpin such that the spring always brings everything back to rest. HTH
#529
Mine was OK for all the run (12x2 BR, Jason ran 4,5BL!!! ) buy very tyre-dependent. 2x pink had not enough grip on this track for rears, so ended with Corally Silver Star. 2x pink on the front was very good.
These critters are faaaasssstttttt !!
#530
surelube
Hey guys! Where can you pick up surelube #4 from??? any help would be wonderful.
#531
I hope the smc saddle fits....
If it does I'm just waiting on being able to order the weighted lipo tray (when they are ready )
#539
wow, i will buy one of these and was wondering if anyone actually fitted a stick style 7.4V LiPo packs down the center. the bmi website says that it would accept it. is it true?
#540
