SERPENT 120
#346
T-Bar back in stock
#347
#351
Correct me if I am wrong, Markus.
#352
The kit I got came with the 6 degree castor blocks which are right in the middle with the optional parts being 3 degree and 9 degree. I think Markus is talking about the latest chassis' have different holes for mounting the servo. That is the only change to the chassis.
#353
Suspended
cant wait to get the 120....
#354
Geez, how sad can it be? I bought two S120 kits and now Im dead in the water with no T-bars to be found anywhere. I hope it gets better and parts start showing up soon.
#355
Suspended
where can i get it in the USA?
#358
Tweak bars
Hi Everyone
Still getting to grips with the car. Nearly there but not quite. The local club has just changed the carpet and its also the first time I've ran brushless so all in all a few changes to cope with.
One niggle is the tweak screws keep coming loose. At the moment I use weak theadlock which normally works fine and doesn't seize the screws in. Any other suggestions please.
On a similar note there was mention of not using the tweak spring adjustment bars but using the tweak screws straight through the slider onto the t-bar. Anybody done this what effect does this have and why did you do it.
Peter
Peter
#359
#360
