Team Magic E4 Thread >
Old 11-19-2007, 01:53 PM
  #271
Jochim_18's Avatar
my team magic E4 is on the way i purchased one off ebay for $365 shipped
Jochim_18 is offline
Old 11-20-2007, 09:20 PM
  #272
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Is there any set ups for this car yet?
Or do I have to figure out my own?
BlackedOutREVO is offline
Old 11-21-2007, 01:51 AM
  #273
gansei's Avatar
Default E4 mid size (28x14m) medium/high grip carpet indoor track setup
- Kenneth Södergård -
File Type: pdf
gansei is offline
Old 11-21-2007, 07:14 AM
  #274
yyhayyim's Avatar
Trader Rating: 26 (100%+)
So who will be stocking these cars and parts for it here in the US? Do they have a website? I need to get my sources ready for this car...
yyhayyim is offline
Old 11-21-2007, 10:16 AM
  #275
Speed World Raceway and hobbies is going to have everything.... Parts, car ETC
http://www.speedworldraceway.com/
I believe he ships also
  #276
Old 11-21-2007, 04:01 PM
  #277
Jochim_18's Avatar
check this website http://www.jbhobbies.net/ it's my friends online hobby shop his from Fresno, CA. I just emailed him yesterday he will be stocking kits and parts for this car. He got the team magic E4 listed for $389.99, He also told me that he gets parts directly from team magic.
Very nice guy I raced with him every week......
Just tell him "KIM" sent you and he will hook you up....
Old 11-22-2007, 03:34 AM
  #278
nutsisneat's Avatar
What result did Kenneth acheive?
I'd like to know how competitive the car is...
Does anybody know?
nutsisneat is offline
  #279
nutsisneat's Avatar
Old 11-22-2007, 06:27 AM
  #280
yyhayyim's Avatar
Nice...
yyhayyim is offline
Old 11-22-2007, 08:02 AM
  #281
kentech's Avatar
Does anybody know?
The result in that race was no good at all...
However, it's hard to judge the car based on that. First of all, I'm no top class driver. Second, I got the car a few days before the race and did 2 packs with the car before qualifying started and had no spare parts...
Towards the end of the race I think the setup was about 80% there. It felt ok on the track in the end and looked ok. It still needed more work though to get it to be consistent and easy to drive over 5 minutes. I also would have needed to find 2-3 tenths in lap time.
I have been very busy lately so unfortunately I have not managed to run the car extensively after the race.
The car has many nice features and comes very nicely presented. On carpet (the only surface I have run it on) I would say it still needs some work to get it to perform optimally at the highest level. If this can be reached just by perfecting the setup or if it needs some developments - I'm not in a position to answer, due to my limited time with the car.
Kenneth
kentech is offline
Old 11-22-2007, 08:36 AM
  #282
gansei's Avatar
Default my E4 setup
it's my E4 outdoor setup (middle ~ large circuit)
i made 1.4mm stebil bar cutting long body pin.
gansei is offline
Old 11-24-2007, 08:52 AM
  #283
gansei's Avatar
K Factory is proud to present the latest option part for the electric touring car. The TC Motor Cooling Head will fit the Team Magic E4 perfectly, as well as any other electric car with a transverse mounted motor.
The TC Motor Cooling Head is machined out of aluminium, anodized black and will effectively cool the motor due to a well thought-out design. Compared to most other heat sinks, the fins of the K Factory TC Motor Cooling Head is turned 90 degrees. By turning the fins this way air will be able to constantly pass through the heat sink. This means that the heat sink will be much more effective, using the airflow inside the car to help increase the cooling effect dramatically.
As to further improve the cooling effect, K Factory exclusively includes a special thermal pad with each TC Motor Cooling Head. The improved cooling effect of the TC Motor Cooling Head means that your motor will perform at its highest level for longer, perhaps giving you that crucial advantage needed! Efficiency will be dramatically improves, while a cooler motor also means less wear, prolonging the life of your favourite motor.
To give the TC Motor Cooling Head that K Factory look, the beautifully machined lightweight heat sink is anodized black and engraved with the K Factory logo.
Fits on most electric car with a transverse mounted motor
gansei is offline
Old 11-24-2007, 09:43 AM
  #284
razzor's Avatar
If they could incorporate a fan then it would be even better.
The nosram heatsink i think is the best.
razzor is offline
Old 11-25-2007, 04:03 PM
  #285
Jochim_18's Avatar
I got the car put together today, But damn the belt is just way to tight. So right now I have the belt soaked to WD40 see how it feels tomorrow. Car was really easy to put together quality is very good, I can't believe how narrow the chassis is. I thought my MI3 have a narrowest chassis but not!!!!!!!!!!! I'm running brushless using GTB ESC so it will be a tight fit.....
I also used the tamiya spring, See how that works. But need to get some more HPI springs.....
I also need to get a low profile servo, standard servo is sticking out too far.
Well so far soo good. sucks that I can't run this car probably not till about next year....
