Pro10 Class
#466
Trackdesigner - I can agree with just two classes. But 7.4 lipo and 4cell in GT. Is that what you wanted, or should it all be 7.4 lipo / 6 cell with just a change of motor?
If your going to follow ROAR, then it would be 17.5 vs 27t and 13.5 vs 19 turn. I don't agree with these but if they are the rules lets follow them until they change.
#467
Wow, how many posts bitching about batteries are there going to be? It's turned a thread about an awesome class that I'd like to see make a comeback into a thread I don't want to read.
I've run both 4 cell 19 turn and 6 cell stock in a pan car at my local track and their both fast (for the size of the track). Let the clubs decide individually and let's just race.
#468
grenade10, you think that 1/12 should play off the carpet? i think that 4WD should go off on asphalt, and pro10 should do carpet as well. Why the hell would you stop racing 1/12 carpet, thats on of the original carpet classes. 4 cell is just not as much fun as 6 cell outdoors, on asphalt especially.
#469
#470
Personally I just want to see the class come back too and all this talk of 4 vs 6 cells vs LiPo and what not has been very annoying. All I am trying to do is have an idea of something that can be workable as a spec that the clubs can readily deviate from as need be but still allow for as many peopel as possible to get involved, and yet be able to have enough people in teh same boat that as this class grows, there is a chance to have a "national-type" event for them like the Vintage class is doing. Really the people that are polarizing the whole 4 vs. 6 cell are in the minority in this discussion. I just want everyone to realize that we are all on the same team here and all this arguing over whether we shoudl run 4 cells or 6 cells or LiPo or car ripping the batteries out of our daily drivers and tossing them in these cars (after someone invents a shrink ray) really is going to keep this from totally getting off the ground
#471
It doesnt really matter what you run. If i was to run a class that wanted to run 6 cell nickle metal packs and a stock motor, I would still run 4 cell and a mod motor. 6 cell stock is about the same speed as 4 cell mod and the 4 cell car is much lighter and will outhandle the 6 cell car no problem. If lipo is run then i will run the 7.4 lipo. 6 cell should just be left in the past with 7.4 lipos coming into play. I just dont see why anyone would want to run 6 cell.
Most all of the tracks in the US will be too small for these cars to run 7.4 volt lipo and mod. You will need a big 1/8th track to run that. Mod 4 cell is a handfull on alot of the US tracks. My suggestion is to try it, see how fast these cars really are and then make your decision on the batteries to use. I just ran 4 cell mod today in my DB10R and was blistering fast. It was almost too much for the track. 7.4/ mod would be absolutely impossible on tracks this size. You will all soon see with your own eyes the speeds you can put together with these cars.
#473
So based on the track, either may work, but I like the 200mm GT with a lipo and 21.5 or 4 cell and 17.5 for the entry class.
BTW - We have a few of you 1/12 scale cars at our track......Nice work!!
#475
Here are pics as promised.
What i did was make it fit 4 cell or 7.4 lipo saddle pack grouped together as a brick pack. This was based on the dimensions of the new trackpower lipo. I moved the electronics to the rear so you can center the brushless speedo to balance the car without adding weight. You also use less wire which helps with any voltage loss through long wires. Another plus is that it gives you centralized mass from side to side and front to rear helping the car rotate better. You will also be using the weight of the brushless speedo when running lipo to your advantage by adding that weight to the back of the car.
I went with losi style battery mounting with a dropout tray that is fixed with 2 4-40 screws to remove the battery out of the bottom of the car. There is adjustable flex points in the chassis for tuning to different track.
I really hope you guys like what i have come up with. We track tested the car and it really was amazing.
#476
Lead weights store easier!
#480
Protc3
The car looks great along with some great ideas on placement of batteries and speedo.
1. What is the target release date?
2. What kind of price is the kit going to have?
3. Will tires be included in the kit?
4. If tires will be included what type will they be?
5. This will be a 200MM car correct?
