CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 01-29-2009, 08:15 AM
  #661
bsmooth's Avatar
Trader Rating: 18 (100%+)
Default weighted battery tray
..Could you guys tell me where you get the weighted battery tray when running lipo?
Also, on that note, if i'm using a 5000MAH lipo with a 'weighted' battery tray will this put me over the minimum weight, and by roughly how much?
Thanks for any help.
-Steve
bsmooth is offline
Old 01-29-2009, 08:20 AM
  #662
liljohn1064's Avatar
Trader Rating: 17 (100%+)
-Steve
I'm running the stock tray, Yeah! Racing 5000 mAh lipo and a 21.5 Novak. The car is 1 oz. over weight at 2 lbs. 9 oz. The losi metal lipo tray can be ordered from just about anywhere if you need it. My LHS keeps them in stock and I'll pick one up if I need to switch to a lighter battery. Right now everything fits like a glove with no slipping or space issues at all.
liljohn1064 is offline
Old 01-29-2009, 08:41 AM
  #663
Scott B's Avatar
Trader Rating: 47 (100%+)
-Steve
Here you go Steve...
http://www.amainhobbies.com/product_...ducts_id/33168
Did you get one???
I built mine basicly stock, buy used 30,000wt oil on the damper tubes. I have tryed a 30lb rear spring, but that didn't change much..
email me if you have any questions... [email protected]
Scott B is offline
Old 01-29-2009, 11:50 AM
  #664
Verndog's Avatar
Trader Rating: 16 (100%+)
-Steve
I'd suggest setting the car up and getting it balanced before buying a tray. After I balanced mine to make up for the ESC being heavier. I was very close to min weight with stock tray and IP3800 battery.
My battery is prob. a good 1.5-2.0 oz lighter then yours.
Verndog is offline
Old 01-30-2009, 05:40 AM
  #665
bsmooth's Avatar
Thanks for the info boys.
bsmooth is offline
Old 01-31-2009, 11:50 PM
  #666
bsmooth's Avatar
Default ball links are too tight!
Ok, so i'm building the car, and I notice the rear plate links are too tight. The plate doesn't seem to move freely, and is very sticky. I squeezed them with some pliers, and this helped a little, but they are still too tight!
And yes, I have already loosened up the middle ball.
What do you guys do to remedy this?
Thanks,
Steve
bsmooth is offline
Old 02-01-2009, 12:06 AM
  #667
smyka's Avatar
keep using plyers the new balls for the side links are a little bigger on purpose
smyka is offline
Old 02-01-2009, 08:01 AM
  #668
Lotus111's Avatar
Hi together
I just uploaded some videos on my youtube portal http://de.youtube.com/user/stecher111 from a Pro10 race held in Metteheim in south Germany. Its in fact a very nice Racetrack with some challenging corners
enjoy
Lotus111 is offline
Old 02-01-2009, 09:29 AM
  #669
bsmooth's Avatar
Thanks, i'll do that.
Was there a problem with the links popping off on the smaller balls? I currently have a GenX-12, and have never had an issue with the links popping off (and the movement has been very free from the beginning).
Thanks again,
Steve
bsmooth is offline
Old 02-07-2009, 07:56 AM
  #670
Default New IRS Axle Assembly for Gen-X 10
Although Dave Irrgang doesn't yet show it on the IRS website yet, I did order and receive one of his complete axle sets for my Gen-X 10. Dave bills it as a "WGT" axle.
Assembled it last night and the fixment is excellent. Thanks Dave.
Will get the Slapmaster treatment when those parts arrive...he, he, he. Should have more information after I test and race at the reborn NorCal Hobbies carpet track tomorrow.
Still Bill is offline
Old 02-07-2009, 08:10 PM
  #671
ChadRacing's Avatar
can anyone help me figure out the proper gearing for WGT? I am running a Trinity Pulse 13.5 on 4cell. The track is a medium size and has medium to high traction. Im not good at figuring roll out. Any help with finding out a starting gearing point well be very appreciated.
ChadRacing is offline
Old 02-09-2009, 03:23 PM
  #672
bsmooth's Avatar
Default traction rolling!!
Guys, could any of you give me some ideas on how to get rid of this? I'm running on a high traction carpet track.
Symptoms: Car has a ton of front and rear grip. I can go into a corner pretty hard, turn it in and its ok. But I have to let it roll through the corner. If i pick up the throttle before or slightly after the apex, the car will bicycle, or snap roll!
Heres my setup (from memory)
Jaco spec tires trued to 56mm (front sidewalls glued)
Blue (x-firm springs in front)
2 deg camber
#5 castor blocks (i think- not a lot of caster anyway)
0 deg toe
4.5mm ride height all the way around
red side springs
30,000 in the tubes
race droop= level
kit losi shock spring
kit shock oil
kit battery tray w/ 5000 ma lipo
195mm front width
200mm rear width
middle hole wheelbase (kit setup)
That's all i can think of.
I'm going to try the heay losi battery tray next, but what else can i do?
Thanks,
Steve
bsmooth is offline
Old 02-09-2009, 07:01 PM
  #673
Thanks,
Steve
Steve,
Yep! I experienced the same thing when the traction came up on my first race at Chico.
You didn't notice how Doug (and Marshall) successfully runs itty-bitty tires at Chico when the traction goes up...they be way under 56mm.
Get it down to 4mm ride height too.
The Losi steel tray will make you way over weight with a 5000 pack. Last resort; but, maybe necessary if the above two suggestions don't take care of your issue completely.
Bill
Old 02-09-2009, 07:14 PM
  #674
bsmooth's Avatar
Originally Posted by Still Bill
Steve,
Bill
Thanks Bill,
i'll try that. were you up there this past weekend?
bsmooth is offline
Old 02-09-2009, 07:35 PM
  #675
Thanks Bill,
Was tempted; but, the 3+ hour drive each way is hard to justify when NorCal is 20 minutes away. Probably will just show up for the final weekend because A-Main is so cool.
