Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 08-08-2010 | 10:05 PM
  #12916
F N CUDA's Avatar
Hey Granpa,
For what it's worth, I run 64 pitch (corrected from 48p) pinions with Tamiya spurs on my F1's all the time without consequence.
I heard that it's wrong but all I notice is a little noise, kinda the same as a nicked spur.
F N CUDA is offline
Old 08-09-2010 | 01:39 AM
  #12917
sosidge's Avatar
Originally Posted by F N CUDA
Hey Granpa,
For what it's worth, I run 48 pitch pinions with Tamiya spurs on my F1's all the time without consequence.
I'm amazed you can run a 48dp pinion with a 0.6mod spur. They are VERY different. 0.6mod comes out roughly the same as 42dp.
0.8mod (which is what some of the basic Tamiya buggies still run) is about the same as 32dp.
0.4mod (which is what some of the higher-end on-road cars are supplied with) is about the same as 64dp. They can mesh, but not cleanly.
sosidge is offline
Old 08-09-2010 | 02:44 AM
  #12918
Originally Posted by Granpa
Tony, you're right. Should have checked your site. Am properly chastised.
gtfour93, the 20 pinion in the link you provided is for a 48 pitch pinion. Unless I'm really wrong, these don't work in a Mini. The Mini uses a metric pinion which I was able to find at Tower, so Thanks for trying.
The Robinson pinion is well made and has the advantage of a stronger set screw hole and is less than half the cost. The Tamiya Flourine coated pinion lasts but eventually the set screw threads give up.
I am not 100% sure about the 48 pitch and metric info, but I'm sure there are a number of Mini gurus who can set us straight
Grandpa sounds like you found the correct pinion.
The M03/M05 uses .6 module pinions. This is the same as Robinson Racing's Metric 48 pitch pinions found here (20T) http://www3.towerhobbies.com/cgi-bin...?&I=LXEX43&P=7
But the setscrew uses is a standard allen wrench and not a metric one.
Sydewynder is offline
Old 08-09-2010 | 04:28 AM
  #12919
rccardr's Avatar
Correct. And it's a larger 5-40 size, so it lasts much longer than the smaller standard 4-40 set screw. Me likey!
rccardr is offline
Old 08-09-2010 | 09:36 AM
  #12920
F N CUDA's Avatar
My bad, I should have said 64 pitch is what I run.
The 48 pitch is on my offroad stuff.
Sorry and thanks.
I'm gonna fix my post above.
F N CUDA is offline
Old 08-09-2010 | 11:37 AM
  #12921
What is the difference between the Tamiya "M" and "S" tire compounds?
Thnaks
Bob
bob o is offline
Old 08-09-2010 | 11:52 AM
  #12922
From what i was told
M = Medium Grip
S = Super Grip
S Grips are Def softer tire
Dunkin is offline
  #12923
superspeed's Avatar
wow, I remember coming to this thread several years ago. It's still going, haha. I guess the admin don't really do much maintainence.
M - medium/hard compound, it's usually the stock tires that you get from the kit.
S - soft compound (s-grip), it's a tamiya hop-up item.
superspeed is offline
Old 08-09-2010 | 11:57 AM
  #12924
superspeed's Avatar
I don't recall any 64 pitch gears for M chassis. Only saw them on formula one cars. When dealing with 64 pitch, there is no metric vs american. However on 48 pitch, there is metric and american. If M chassis can use 64 pitch gears in the future, that will be very cool and more efficient. M chassis is known for noisy gearbox.
Old 08-09-2010 | 11:58 AM
  #12925
there is 3 types of mini tyre from Tamiya
kit tyres (hardest)
M grip (medium and shortest life)
S grip (soft but last longer than the M grips :S)
this is my limited experience though
sidecarphil1 is offline
Old 08-09-2010 | 12:00 PM
  #12926
k_bojar's Avatar
M - is a different compound then the kit tires...the M-Grip and kit tires are 2 completely different part numbers, so they aren't the same
k_bojar is offline
  #12927
M03Racer's Avatar
Why would the admin have to do any maintenance when we communicate and share helpful and useful info about the mini.
M03Racer is offline
Old 08-09-2010 | 12:27 PM
  #12928
MD's Avatar
MD
Where do the type "A" slicks fall into the compound range? And, now they are a "B" compound.
MD is offline
Old 08-09-2010 | 12:35 PM
  #12929
superspeed's Avatar
type A is softer than type B.
I recall type A works good on Carpet, it had some temperature rating listed on the back of the tire box.
Type B is a good choice for running outside on asphalt, it can handle higher temp and rougher surface.
Tamiya made type A belted slicks before, those are very sticky and easy to traction roll the car.
Old 08-09-2010 | 12:36 PM
  #12930
superspeed's Avatar
just making a bad joke to the admins here, that's all. no hard feeling
