Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 02-26-2009 | 09:29 PM
  #8431
monkeyracing's Avatar
R/C Tech Elite Member
Originally Posted by tony gray
Jim - are the medicines in Canada only half strength at the moment?
No. They're double strength. I think that may be the problem.
Jim
monkeyracing is offline
Old 02-27-2009 | 05:29 AM
  #8432
Moole's Avatar
and what about this ones?
will they fit?
3racing alum damper set for m03
@ rcmart
thanks
Moole is offline
Old 02-27-2009 | 06:05 PM
  #8433
Yup, they're good. I've got a set. They seem to be pretty well put together. The adjuster rings are kind of hard to turn, but if you remove the teeny o-ring they put inside them, it's easier to deal with.
Jim
Old 02-27-2009 | 08:26 PM
  #8434
What is the best way to clean and re-lube the silver can motors?
SUNA is offline
Old 02-27-2009 | 10:00 PM
  #8435
hairy's Avatar
I spray mine out real good with motor spray and then blow it dry with an air hose.
hairy is offline
Old 02-28-2009 | 12:20 AM
  #8436
Moole's Avatar
thanks monkeyracing
Moole is offline
Old 02-28-2009 | 03:53 AM
  #8437
edwintklee's Avatar
Edwin - it applies to ALL M03's whether you use dogbones or unis.
tonys,
its this done to make sure that the giff cups do not move when its turning?
cos if uj ,the long end position its fixed, no movement to the long bar, the only piece that its able to move its diff cups,
if use dogbone, the bone its not fixed to any position, its best to use the foam to add tention between the diff cups and the dogbone position, so the dogbone and diff cups will be in a fixed position...and will not moved when its turning....
please correct me if i am wrong.....
edwintklee is offline
Old 02-28-2009 | 05:45 AM
  #8438
RMF-888's Avatar
has anyone knows the part number of the hpi xpattern tires?
tnx
RMF-888 is offline
Old 02-28-2009 | 06:12 AM
  #8439
edwintklee's Avatar
tnx
hpi 26mm = 4790, the small 1 i forgot....
Old 02-28-2009 | 07:32 AM
  #8440
tnx
for mini? 4565.
stocker is offline
Old 02-28-2009 | 08:26 AM
  #8441
Moole's Avatar
hello everybody
will these fit on my mini??
LN-0001YW @ rcmart
tia
Moole is offline
Old 02-28-2009 | 11:26 AM
  #8442
tony gray's Avatar
Originally Posted by edwintklee
tonys,
You're partly right...
The whole point of this is to keep the outdrive (the bit that sticks out of the chassis from the diff) firmly stuck IN place. And whether you use dogbones or unis the intent is till the same. Keep that outdrive in place.
Foam degrades and loses it springiness, rubber o rings perish.
So if you want to take it to the final degree, yes maybe if you're using dogbones you might want to put an or ring in the outdrive and one out in the hub as well. BUT...often this will be too tight and bind the whole system up.
I don't use dogbones anyway though...
tony gray is offline
Old 02-28-2009 | 03:40 PM
  #8443
tony gray's Avatar
The first chrome 'race chassis' has been built, and is probably racing as I type this..
Check it out here
Old 03-01-2009 | 12:35 AM
  #8444
There are two good methods. One is to use a light comm drop and run the motor at low voltage for a couple of minutes then spray with motor spray. This method is courtesy of Doc Mertes.
The second is easier and is for guys who don't have a motor tester or motor run feature on their charger. Use liquid metal polish like Brasso and apply it directly to the comm. I use a oil bottle with a needle type tip. Leave the pinion on or put one one and spin the motor over or roll it back and forth on a towel on your pit table. You can clean out the polish with water or motor spray. If you use water, air dry the motor.
If you clean the motor every couple of runs, Doc's method gives you a beautiful shiny comm. If you're lazy like me and only clean the motor at the end of the day, the brasso is much quicker.
Granpa is offline
Old 03-01-2009 | 07:36 AM
  #8445
Got a question for those using the M03R front uprights. In what situations would you use one of the 3 holes over the other?
stocker is offline
