Tamiya mini cooper
On the subject of the new R kit, does anyone have experience with the big bore dampers from this kit? I've got them on my M03 with 35wt Associated oil and they feel very over damped. I think the white piston holes are too small, and the black pistons are a smaller outer diameter so probably won't fit well. Are there other piston options?
The best setting for me is one that is pretty loose almost near bouncy but still damped.
Bashing, since all tracks are far from me. The reason why I was considering the pro race, is because I am the type that would upgrade forever, but wants to save money. So value and performance are important.
I ended up spending about the same amount of dollars on the xv-01 hop-ups compared to the kit price. I should have just got the TC version to begin with.
Regarding the motor mount, looks like i have to suck it up and buy the tamiya one.
Hey guys, does anyone can tell if hobbywing quicrun 10bl60 sensored 60a esc can support using bluebird dmg621 servo without adding external bec??
The esc paired with xerun 17.5t motor
Just wondering..
This is the esc spec
Model: QUICRUN-10BL60-SENSORED
Cont./Peak Current/ Resistance: 60A / 380A / 0.0008 Ohm
Motor Type Supported: Sensored / Sensorless Brushless Motor
Car Applicable: 1/10 & 1/12 On-road / Off-road / F1 / Drift car race / Street race for fun / Club racing / STOCK race with 0 timing / Drift car race
Motor Limit:
For 4-6 cells NiMH/2S Lipo
≥8.5T(1/10 On-road), ≥13.5T(1/10 Off-road) *"T" indicates the limit value of motor turns when the ESC timing is set to 0. The larger the timing, the more turns the motor needs.
8-9 cells NiMH/3S Lipo
≥13.5T(1/10 On-road), ≥17.5T(1/10 Off-road) *"T" indicates the limit value of motor turns when the ESC timing is set to 0. The larger the timing, the more turns the motor needs.
Battery: 4-9 Cells NiMH / 2-3S Lipo
BEC Output / Operating Voltage of the Cooling Fan: 6V@2A, Linear Mode / 6V (The cooling fan gets its power supply from the built-in BEC)
Dimension / Weight: 33mm(L)*28mm(W)*31.5mm(H, with cooling fan) / 59g (with wires, without cooling Fan)
Just wondering..
Motor Limit:
By the way, thanks for letting us know about that deal. Good looking out.
I just checked the XErun specs. it's 6V@3A. So 2A is borderline questionable.
I am not sure about the Quicrun, but the Xerun that I own (with 13.5t), has built in receiver capacitors dangling off the side. It has more than enough juice for my Futaba high torque servo and receiver. If you check the BEC spec on the XErun, and it has the same amp rating as the quicrun, you should be good without having to use anything more.
Quicrun is 2amp
What amp xerun esc you have??
I was (this) close to pulling the trigger on the pro-race because of that 40$ off, but then thought about the consequences by having to explain to the wife how a new car got into my RC garage. "I tripped, (finger slipped) and now its here." Yeah right! 😚
Still trying to justify it, I've recently upgraded my M03 with CVDs and big bore dampers but haven't had a chance to run it yet due to a broken finger and recently moving house
295Likes
